Introduction: Solar Step Lighting
Picture of Solar Step Lighting
Step lightings are costly to fix and waste energy to run. Why not go solar for a buck?
Step 1: Cheap Solar Light Hack for Step Lighting
Picture of Cheap Solar Light Hack for Step Lighting
This hack is to replace non functioning step lighting with solar garden stakes from the dollar store. Works best for south facing sides, not recommended for shady areas since it is solar.
Step 2: Things You Need
Picture of Things You Need
Garden solar lights from dollar stores or $0.97 from walmart.
Sharp scissors
Mini screwdriver
Caulking - squeeze tube is ok
Optional:
Razor blade
Soldering iron and solder
More low voltage wires if you need the wires to be longer
Step 3: Dissemble the Lights
Picture of Dissemble the Lights
You are getting a lot of bang for your buck! After some pulling, pushing and twisting, you should be able to take the black top out exposing the mini screws next to the led. Unscrew them and the whole thing should come apart.
Step 4: Remove Excess Plastic Next to Solar Panel
Picture of Remove Excess Plastic Next to Solar Panel
BE CAREFUL WHEN HANDLING THE SOLAR PANEL. Try not to pull the wires as it may become loose then you will need to solder it back. Or try prying the panel out, i believe it is glued down so you risk damaging it.
I decided to cut the plastic around it instead. Use scissors to make 4 cuts on each corner, the just peel the plastic back and cut it with razor blade. I trimed the little legs sticking out on the back as well. The plastic is really soft and easy to work with.
Step 5: Optional- Trimming the Light Assembly.
Picture of Optional- Trimming the Light Assembly.
My existing housing is too narrow so i had to trim it to fit inside the housing.
Step 6: Caulking....
Picture of Caulking....
Step 7: Put the Light in Place
Picture of Put the Light in Place
Caulk everything and put the light into place with the panel hanging out.
Step 8: Ta-da!
Picture of Ta-da!
It worked perfect! Let me know what yall think!
DIY Hacks and How Tos (author)2016-06-07
Nice solar lighting project. You should enter this in the Renewable Energy contest.
Just did! Thank you!
About This Instructable
852views
16favorites
License:
More by PiguCoupon:Doctor Who TARDIS Explosion PaintingTarget Sunburst Decor CopycatTouch Lamp Conversion
Add instructable to:
