Solar Still
3,322
70
Posted in HomeLife-hacks
Introduction: Solar Still
About: Thanks for Viewing
This instructable is showing how to make a solar still using mirrors as reflectors.There is a dark bottle with a quark inside a glass jar with a lid. From this bottle there is a copper pipe in a quark going to a 12 ounce beer bottle that the contents are going to drip into. The glass jar with the bottle inside will sit in the frame of mirror to attract more heat.
disclaimer- I am not responsible for what anyone does with this any information on here. read about how solar stilling works before making. You need a permit to distill alcohol. There free to get online. might depend on state.
i used copper pipe
Step 1: Tools and Supplies:
Tools
jig saw/ hand saw
drill
sander
copper pipe cutter
hammer
wood for frame
mirrors 1 ft square 3
big glass jar with lid
colored bottle
quark to go in colored bottle
quark to go in 12 oz bottle
copper pipe
glue for mirrors
nails
Step 2: Make Wood Frame:
To make the frame I had spare wood around I used. It was a half inch thick, I cut it so that I had 3 pieces about 13 inches long. The mirrors are 1 foot square so the wood has to be big enough for the mirrors to be glued to it. Before nailing the wood I set them up to see how they would look. The 2 side pieces I nailed to the base then nailed these to together. make sure you have straight cuts so it is all square.
I added rain protectant to the wood to have it last longer outside..
Step 3: Add Mirrors and Bottles
Adding the mirrors is pretty straight forward. I used the silicone glue. This is the type that goes in the metal sqeezer that pushes out the silicone. I first glued the base mirror on to the bottom. I set clothes on the mirror and and added weight until it dried. Then I did the same thing with both the side mirror. I turned the side so that it was on the ground when I Glued the sides down.
Adding the bottles is easy you just have to find the right sizes. I used a pickle jar for my main big clear jar. I then found a dark beer bottle that fit inside this jar. I believe it was a 18 ounce bottle or 20 ounce. Once I tested it fit inside i cut out a hole in the top lid for the top of the bottle to poke out the top. The other bottle is a regular high life bottle.
Then lastly add your conditioned copper. Make sure your copper is conditioned. you need clean off the copper with rubbing alcohol and clean it off.
If you make this make sure you do your homework on how stilling spirts work. The mirrors part can also be used for other solar applications.
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    Have you tried this to make sure it works as it should? I dont see how it would work without a way to cool the steam.
