This device operates by harnessing the ability of certain polymers (in the case black plastic bags) to shrink when exposed to heat, and relax back to their original length when cooled.
Normally, this shrinkage occurs in all directions within the material. However, the material can be stretched, causing its polymer strands to line-up, and directionalizing the shrinkage.
The solar thermal motor operates by using bands of stretched black plastic bag to continually pull a flywheel off-center as it rotates on an axle. The strips are heated by sunlight on one side of a drum/flywheel assembly, pulling the flywheel toward the sun-side. As the strips rotate to the back, they cool in the shadow of the drum and relax. This makes the flywheel continuously off-center on the sun side, causing it to rotate.
SolarMotor.AVI6 MB
Remove these ads by
Signing UpStep 1Tools and Materials
1x Black plastic trash bag
2x Styrofoam cups
1x 1/8" wooden dowel 12" long
1x Styrofoam freezer tray
2x Sewing pins (Forgot these in picture)
1x Plastic yogurt (or similar) lid approx. 4" dia.
1x Scotch tape
2x Tin cans
Tools used:
-Single edged razor or xacto knife
-Drawing compass
-Felt tip marker
-Ruler (forgot this in picture)
-Sizers
-Glue gun
Would it be able to move air through a passive solar air heater? It could complement some of the other solar air projects that rely on thermosiphon effects to circulate air through them.
Title: Build a sun tracker and a solar engine with solar muscle
Personal Author: RAY, Edward D.
Journal Name: Popular Science
Source: Popular Science v. 216 (February 1980) p. 126-8
Publication Year: 1980
Physical Description: Illustration
ISSN: 0161-7370
Subject(s): Solar engines
Historical Subject(s): Solar engines
Document Type: Feature Article
Database: Readers' Guide Retrospective
Accession Number: 198003201152027
Check you local library's microfilm department for a copy.
Otto
(German genes, Irish whiskey --- what could possibly go wrong?)
"Use scotch tape to center the open end of the cup to the dowel." (Step 7)
> This instruction needs a bit of clarification, and a better photo, please.
