Step 9Final Step!
Rest the axle pins in the notches of the cans.
Although your solar motor might be ready to use now, it is a good idea to balance test it first. Give it a spin. If it looks like it if heave on one side, add weight (pins, small brads, etc) to the opposite side until it is balanced.
Note: add the weight to the Styrofoam Back disc, Not to flywheel.
You are done!
Put the whole assembly in the sun - if everything is built right, if will begin the rotate. The more balanced it is, the faster it will spin.
Would it be able to move air through a passive solar air heater? It could complement some of the other solar air projects that rely on thermosiphon effects to circulate air through them.
