3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solar Thermal Particle Panel
I have been trying to figure out how to make a cheap solar thermal panel.  Like this instructable, I settled on plastic.  There is one BIG problem with making a solar thermal panel out of plastic.
Overheating
The problem, put simply, is that plastic solar thermal panels, if built like traditional solar thermal panels, cannot turn themselves off if they start to overheat. You cant just paint a plastic panel black and slap some glazing on it.  If you stop removing the heat from the panel, and the panel is built from plastic, it will soften or melt eventually. This was recognized by Rob in his instructable:
"because the whole collector is made of plastic, it is important that the temperature doesn’t get too high or it will soften and possibly spring a leak. 80 degrees C (176 degrees F) is about the limit. Don’t think it can get that hot? Think again. ...Therefore this may not be a practical design for residential installation"
The problem is figuring out how to make a solar panel turn off.  If you can figure this out, then solar thermal panels could be built of plastic and the cost reduced to a point where it is affordable to everybody. (i.e. $1000 per panel to $200) Why is this important? Because heating our homes (air and water) accounts for the majority of energy we consume in our homes.  If solar thermal panels were cheap, we could heat our house with them and save billions every year.
So this is where I am coming from.  I want to find a way to build a solar thermal panel from commonly available materials and have it compete with commercial systems.  The design I have come up with may be the answer, or it may not, but if the instructable community would work on this problem with me, the benfits to our society could be huge.
check out the blog I created for this idea for more info and for updates as I have them.
Blue Skies,
Alex
Step 1Use Polypropylene, not Polycarbonate
Until I have a chance to redo the figures (maybe in a week or so), to any users out there who wants to build this panel:
Don't use polycarbonate!
Turns out that this plastic degrades in long exposure to hot water.  Following up on some user comments, I checked out Coroplast, which is actually polypropylene plastic. long story short, coroplast is MUCH cheaper, MUCH more water-resistant (its used for plumbing) and easily recyclable.  Not even any question about what is the better option.
However, you will have to heat-weld the manifold because polypropylene does not glue easily. Read about it at Wikipedia.  Until I have the time to test this, and unless you want to give it a try, I recommend just thinking about this idea and coming up with more ways to make it better.  There is obviously a lot we can do!
43 comments
1-40 of 43next »
May 30, 2011. 12:52 AMmalaskadora says:
HI, I'm from philippines and energy cost is quite expensive. It's good to know that this kind of technology is growing. However, here in my country doesn't seem too interested on this. I want to build or make one for my own. I need your ideas about this, and I reckon if you could help me on this one. http://build-home-solar-panel.com/
I saw this site and I need your inputs. I want to have at least one guide for now. Thanks in advance!
Nov 9, 2010. 6:12 PMglorybe says:
In essence you need a door like object that is set to close when the internal temperature is too high. The door will shield the unit from sunlight thus allowing the unit to cool. I do warn people however that metal is to be trusted in building collectors. The flash point for wood could easily be exceeded in a solar collector and a fire on a roof is to be avoided at all costs.
Aug 17, 2010. 6:07 PMpashute says:
Here's a simple solution: Black tubing can stand in the field in the hottest summers for 10 years. Polygal [http://www.google.com/search?ie=UTF-8&q=polygal+images] is built as roofing material, is low cost, has a good insulation for the lower and higher layers, so that heat is not lost to the roof base or to the air above. Insert the tubing in the middle, and you have exactly what you wanted.
Aug 19, 2010. 1:18 AMpashute says:
In fact, there is an Israeli company that built for a large industrial project in Brazil, with EXACTLY Polygal. The hot water passes in standard (for Israel) pipes, and this has been field tested for over 25 years!! No risk of deformation whatsoever. (Polygal factory has roofs even older than that, never changed, and still with original form. The old clear ones get a bit "yellowish" over the years. The new ones are treated so that they should stay clear for 10 years and more. (Meanwhile 7 years strong). Tubing from Netafim - the guys that invented irrigation, because they didn't have enough pressure to work the sprinklers. Then discovered that it works much better... http://www.netafim.com/success-stories or Metzerplas from Kibbutz Metzer who copied the system: http://www.metzerplas.com/en-US/61/870/ This stuff is out in the Israeli sun (and freezing cold in winter in the mountain and north areas) in the fields on all parts of Israel. Lasts at least 15 years. The black pipes sometimes reach almost boiling heat, pressure is given off through the irrigation holes. So simply add a few pressure guages that automatically open if the pressure is too high. Also use connectors at the bends, so that they serve as a "fuse" or circuit breaker in case of failure. You can easily fix that by inserting the connector back in.
Aug 19, 2010. 10:15 AMpashute says:
OK, sorry, I read the blog. Let's continue there. Your right about the winter (not much of a problem in my country, and the amount of insulation
Just as a side, I was considering clear pipes and adding particles to the flow (there's a company that does exactly that - adding particles to (and removing them from) liquid flow for various industrial needs.
Aug 19, 2010. 9:52 AMpashute says:
Its hard to read because instructables don't leave the spacing or formatting. [b] Let me try[/b] [br] or this another try
I don't need you to show me the problem. Please understand that I ACTUALLY MANUFACTURED a system like this, after talking to the ENGINEERS at two companies, one of the Polygal (a two hour drive out to Kibbutz Ramat Hashofet).
So let me explain once again: The Polygal is only the structure and insulation. The black piping is what takes the heat, and YES it has worked without failure for over 10 years! I'm not sure what happens when there is no water in the pipe. Seems to me the air heats up, builds up pressure and moves out the pipe, thus cooling it down.
Your right its not a matter of brand, but that company treats its PC so that it is ready for roofing and roof conditions, and, as I stated, it worked already, and works for at least one company for many years. BTW take a look at this - no insulation at all... http://www.youtube.com/watch?v=sBAi_TVNaiM
Aug 19, 2010. 12:31 PMpashute says:
Yes. I misread. I posted a second reply sending us to continue from ur blog.
Apr 25, 2010. 5:28 AMvertig-oh says:
This looks really interesting - great instructable! have you experimented with the minimum angle the panels can be held at before the particles settle on the sides of the channels instead of sinking to the bottom?
Apr 25, 2010. 10:19 AMvertig-oh says:
Oh that's not so bad; I live 54 degrees north :-)
Feb 15, 2010. 6:20 PMrimar2000 says:
Sorry to ask questions that perhaps are already answered, the fact is I don't speak English but Spanish, and I can hardly read and understand all the comments.
I have two questions:
1) Why you use silicon carbonate, not just coal particles, which is much cheaper?
2) Do you think is enough to stop the flow of water to stop heating?
Finally, EXCELLENT INSTRUCTABLE!!!
Feb 16, 2010. 2:46 AMrimar2000 says:
Gracias por tu amable respuesta. Como suele ocurrir, una respuesta ocasiona otra pregunta: ¿Por qué 60um? ¿No podrían ser de 1mm o 2, o de cualquier otra medida?
For the Instructables Anglophone community: Thanks for your kind reply. As often happens, an answer causes another question: Why 60um? Could not be 1mm or 2, or whatever else measure?
Feb 17, 2010. 5:16 AMrimar2000 says:
Thanks for the explanation, it sounds very convincing.
I can read English almost perfectly, aided with Google translator, if the text is wrote in English as yours. I say this because there are others that are wrote in slang.
Feb 15, 2010. 7:14 AMironsmiter says:
I'm not bound to build a panel using this method...
So far it's been much easier using dorm room fridge radiators, and window glass.
That being said, I do have an idea for your 'ible readers.
I've recently built a CNC Guinea Pig cage.
I used a white coroplast. however the sign shop I bout it from also carries the same material in clear.
Advantages are, CHEAP... I think I picked up a 4x8 sheet for $25(though online can be much cheaper if you can talk your way out of shipping). Temp resistant. Well, it'll withstand 60PSI at 200F! So as long as you're using water to move the heat, all should be well.(melting is somewhere over 350F)
This Place has some 'good stuff' rated for hurricane country. they even sell end caps, premade!
Feb 15, 2010. 4:05 PMironsmiter says:
I don't have any long-term data on hand... but in the 3-4 year range, yes. ANY coroplast should resist UV just fine. Year old political signs still cut/weld/work like new stock...and that's with Chicago smog and salt!
Long term, it MAY develop brittleness... not an issue if it's overglazed, like in your design.
If it's a big concern, one of the optional coatings is UV resistance. don't remember which site, or which product, but the number was 98% light transmission, with "High" uva/uvb resistance.
Just on a side note... Sonic welding is expensive, but best.
Thermal welding works well too though.
I mention this, cause you can cut a few inches on the bottom of the panel in half, Remove the top portion, sand the bottom smooth, form, and weld.
If you're willing to sacrifice the outer most 2 channels... you can make your entire panel from just the one sheet! and if you do the thermal/sonic welding well, it'll never come apart!
If that doesn't make enough sense... I could draw up a cut /weld diagram... but you probably got what I meant :-)
Feb 16, 2010. 12:32 PMironsmiter says:
"How could I get that wire mesh in there? "
That is an issue I hadn't thought of...
My solar heaters don't use an in-water heat absorber like yours does.
I think it may be possible to change the U shape a little and still imbed it.
Feb 17, 2010. 6:45 AMironsmiter says:
I wouldn't use "experienced" to describe what I've done. :-)
My experience to date is NOT with waterproof welding. Just structural.
That being said, my work hasn't let the dust from pet bedding through, and I didn's SEE any leaks last time I washed the pan... So it MIGHT be waterproof. Just don't know.
my "plastic welding torch". Was the cheapest piece of junk I could find that would still do the job, with my skills. If you have the cash, go for one of these.
If you're budget is REALLY low, this was the cheapest one I've ever seen. If you're willing to practice and looks aren't too important, an old junky solder iron should do a passable job, as long as it has temperature control. The cheapest of the cheap iron-style plastic welders are set up like that. So much so, in fact, that most of them look like the seam irons that Hobby Lobby sells, for seamstresses.
Feb 16, 2010. 7:55 PMfuzvulf says:
 Awesome instructable, nicely done.  Appears to work pretty well.  Do you have any data on it yet as to how many BTU's you can get out of it for given light levels?  There is an ible on here somewhere on a light meter, you can get the rest by taking readings of input water temp, output water temp and light levels and flow, or you can take light level readings and set it up with an insulated reservoir and a known volume of water and see how many degrees it is raised over the time of your readings.  From either of those you can get us some good efficiency data.  Great job.
Fuzzy
Feb 15, 2010. 3:01 AMwobblestar says:
Surely step 14 should read "When you turn off the water, the particles should settle and the panel should go CLEAR". That's how the panel"turns off".
Great idea.
Cheers
Mark
Feb 16, 2010. 7:41 PMfuzvulf says:
 If your setup is enclosed in an insulated box with a clear front, a portion of the light entering the collector will be reduced in frequency to the infra-red=(heat).  Glazing tends to reflect ifra-red to some extent while it passes visible light.  It may be necessary to open a sort of vent should the collector box overheat. Once possibility that comes to mind for an inexpensive actuator which would be simple, cheap and with few moving parts would be one using low temp muscle wire activated by the heat of the collector instead of an electrical current.  LT or (low temp) muscle wire actuates at about 70 degrees C or around 160 degrees farenheit which would be about ideal to open a vent to allow the panel to cool.  By placing the actuator lower within the panel one could (fine tune) when it actuates since the upper portion of the panel would be hotter than the lower portion.  Just a thought and my two cents worth.
Feb 15, 2010. 11:53 AMlemonie says:
Silicon carbide - novel use for it I guess?
L
Feb 15, 2010. 12:29 PMlemonie says:
Feb 15, 2010. 3:06 PMlemonie says:
60um - that's dust. Powdered charcoal?
L
Feb 15, 2010. 11:22 PMlemonie says:
I've used test sieves down to 20um - with polystyrene - no joke, that was a drag...
L
Feb 15, 2010. 1:36 AMMike__ says:
To make it turn off, could you use a low voltage sprinkler valve for the flow, and a temperature sensor attached to some point on the panel?
Perhaps a simple thermistor circuit or even a slightly more complex sensor and IC circuit could be used?
Not entirely sure if that is what you mean by "turn off" but it is just an idea.
So now that you have hot water running to your house, how do you convert that to space heating on the cheap?
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:alex n
