Introduction: Solar Thermal Particle Panel
I have been trying to figure out how to make a cheap solar thermal panel. Like this instructable, I settled on plastic. There is one BIG problem with making a solar thermal panel out of plastic.
Overheating.
The problem, put simply, is that plastic solar thermal panels, if built like traditional solar thermal panels, cannot turn themselves off if they start to overheat. You cant just paint a plastic panel black and slap some glazing on it. If you stop removing the heat from the panel, and the panel is built from plastic, it will soften or melt eventually. This was recognized by Rob in his instructable:
"because the whole collector is made of plastic, it is important that the temperature doesn’t get too high or it will soften and possibly spring a leak. 80 degrees C (176 degrees F) is about the limit. Don’t think it can get that hot? Think again. ...Therefore this may not be a practical design for residential installation"
The problem is figuring out how to make a solar panel turn off. If you can figure this out, then solar thermal panels could be built of plastic and the cost reduced to a point where it is affordable to everybody. (i.e. $1000 per panel to $200) Why is this important? Because heating our homes (air and water) accounts for the majority of energy we consume in our homes. If solar thermal panels were cheap, we could heat our house with them and save billions every year.
So this is where I am coming from. I want to find a way to build a solar thermal panel from commonly available materials and have it compete with commercial systems. The design I have come up with may be the answer, or it may not, but if the instructable community would work on this problem with me, the benfits to our society could be huge.
check out the blog I created for this idea for more info and for updates as I have them.
Blue Skies,
Alex
Step 1: Use Polypropylene, Not Polycarbonate
Until I have a chance to redo the figures (maybe in a week or so), to any users out there who wants to build this panel:
Don't use polycarbonate!
Turns out that this plastic degrades in long exposure to hot water. Following up on some user comments, I checked out Coroplast, which is actually polypropylene plastic. long story short, coroplast is MUCH cheaper, MUCH more water-resistant (its used for plumbing) and easily recyclable. Not even any question about what is the better option.
However, you will have to heat-weld the manifold because polypropylene does not glue easily. Read about it at Wikipedia. Until I have the time to test this, and unless you want to give it a try, I recommend just thinking about this idea and coming up with more ways to make it better. There is obviously a lot we can do!
Step 2: Get Your Materials and Tools...
I went through a number of failed attempts before building a panel that worked. Unfortunately, the raw materials are not cheap because you have to buy them in bulk. I have done this, and have lots of leftover particles and wire mesh. If a reader out there would like to build one of these panels for themselves and does not want to buy the bulk materials, please contact me and I'll look into setting up an Ebay shop to sell the excess wire mesh and silicon carbonate particles I have.
You will need:
>double-wall polycarbonate sheet. I used the 5/8'' but I think it would be better if you used the 1/4'' sheet. its cheaper and will probably work out better. I found a local supplier for Macrolux panels. You will have to find a local supplier. They come in 4'X8' sheets.
>65 micron silicon carbonate particles. The particles need to be about 65 microns, black, and as non-reactive with water or glycol as possible. Finding these particles was a bit challenging because I needed them to be pre-sifted down to a very small size. Silicon Carbonate is used in the abrasives industry and is available in 25lb bags. You will only need a few cups, so contact me if you want to buy some of what I have left over. I bought them here.
>40 micron metal mesh. Again, the minimum order here is far more then what you will need. Read this instructable and you will see how much you need, which will depend on how think your panel is. Contact me if you are interested and I can try to add some strips to Ebay.
>Acrylic plastic sheet or polycarbonate. Again, read this instructable to figure out how much you need, as it will depend on thickness of panel.
>heat gun
>table or skill saw (not shown)
>screwdriver
>metal sheet cutter
>plastic cement
>plastic epoxy
>masking tape
>a little funnel (or just make one)
DON'T EVEN BOTHER WITH SILICON SEALANT. IT WILL NOT WORK.
Step 3: Cut the Polycarbonate Sheet to Size
I have tried cutting the panels with a table saw and a skill saw. Both work. I strongly recommend sacrificing a little bit of the panel to use for testing. I think making 4 2'X4' pieces from a single 4'X8' piece is the way to go.
Step 4: Cut the Wire Mesh
Cut the wire mesh into strips about 3/4' wide with the metal sheet cutters.
Step 5: Bend the Wire Strip Over the Top of the Panel
This step is simply to secure the metal strip so it does not move around while you use the heat gun and screwdriver to melt it into the panel. See (1) in the diagram in step 5.
Step 6: Melt the Wire Mesh to One End of the Panel
I tried quite a few other methods before settling on this. Its actually really neat how it works and its simple.
The idea here is to melt the wire mesh into the top of the panel. I will describe this as best as I can, in reference to the diagram. First, insure the wire mesh is bend around the panel (1). Prop the panel up so you do not have to hold it. Turn on the heat gun and let it get hot. While pointing the heatgun at the the metal mesh (2), use the screwdriver to push the mesh into the panel by moving the screwdriver back and forth (3). You will actually see the plastic permeate the mesh. I strongly recommend you practice this on a few test pieces first. However, if you do screw up, you can always saw off the end of the panel and try again. If you apply too much heat, the panel will bend inward a little bit. This is OK as long as its not too severe because the manifold will wrap around the end of the panel.
Once the metal has cooled on a test piece, try to peel the metal off. It should be really hard to rip it off. If it is, you know you did it right.
Step 7: Add the Particles...
use a little funnel to fill each channel with particles. The wire mesh should be bonded to the bottom of the panel, so those particles should not escape. I would wear a dust mask or ventilator here just to be careful. I don't know if Silicon Carbonate particles are bad for you, but I would not want to get that stuff in my lungs. I have two tips from my experience.
First, use about 2 teaspoons if your panel is 4' tall. I used 1 tablespoon and it was too much.
Second, be sure to measure it fairly carefully so that all channels get the same amount of particles.
Step 8: Repeat Steps 3-5 for the Top of the Panel, Sealing the Particles In.
Repeat steps 3-5 for the top of the panel. You should now have a 2'X4' panel of double wall polycarbonate with 2 teaspoons of 65 micron silicon carbonate particles trapped in the channels by two strips of 45 micron metal mesh melted into the top and bottom.
Step 9: Design Your Manifold
We now need to build the top and bottom manifolds. This is how we are going to channel the water to flow through the panel...in at the bottom and out through the top.
What will follow are the steps I took to do this, but in the process I realized a way better way. I would strongly recommend you not do what I did and skip to step 12 where I show you how to make a manifold in one piece. If you are going to build this...innovate it!
Since I did not fully appreciate that I could just bend the acrylic, I cut strips of .2'' thick sheets and glued them together into a "C" clamp shape, as you can see from the magnified side view in the diagram.
Step 10: Cut the Acrylic Sheet Into Strips and Glue Them Together
Again, I recommend you invest some time into learning how to bend plastic. It would be soooo much better. However, here are pictures of what I did. They are pretty self-explanatory. I just cut strips of acrylic and glued them together with acrylic cement.
Step 11: Install Inlet and Outlet Ports
Unfortunitly I did not take a picture of this step, but I messed it up anyway. If you are building the manifold like this, i reccomend you drill a hole in the front of the manifold, not the side. The problem is that drilling into the side can cause the laminated acrylic strips to come apart. I picked up these fitting from my local hardware section in the plumbing section. Drill the holes, screw the fitting in, then take them out and coat it with cement and put them back in to seal them.
Step 12: Glue and Seal the Side Pieces
Cut some square pieces and glue them on the sides of the manifolds. There will be a little gap between the panel side and the side piece. This needs to get filled. I used silicon sealant at first. The problem with that is that there is very little air flow now inside the manifold, and the silicon takes forever to harden. I ended up using a hot-melt glue gun, which took just a few seconds, hardened in 2 minutes and was good to go. No waiting for the impatient (like me).
Step 13: Make a Better Manifold Then I Did!
I realized after I built this that there is a MUCH better way to do this. Bend one piece of acrylic. Less time, less gluing, less potential for leaks or mess ups. I had no experience with plastics before I did this, but man there really is a lot of possibilities.
From what I have look into, you can buy a plastic builder or just make your own. You have to build this wire heating element. I found it for much less here.
Rather then seal the end with a glue gun like I did, I think it may be better to use a polyester resin. However, I am not a plastics expert. That's just what I am going to do for the next version.
Step 14: Admire Your New Panel
As you can see, my panel is not actually 2'X4'. I went through many failed attempts before getting it to work, and I used smaller pieces so i could make the panels that I bought last long enough for me to get it right. As it turned out, that was a good idea. I went through five panels before I got the design I am showing you here. So...learn from my mistakes!
Step 15: Test the Panel
Hook it up to a hose and see if it works. Be sure to connect the input at the bottom. The water needs to flow up through the panel. When you turn the water on, the particles should spread out and turn the panel black. When you turn off the water, the particles should settle and the panel should go black. Why is this important? (See the intro. Still don't get it? Go to my website and read what I have there)
There is a video of me testing my first panel here.
Step 16: Add Insulation
If you build a panel with no leaks, congratulations! I say this because my first panel leaks a little bit, so I am not going to bother insulating it. However, I think it should be easy. Just put some foam on the back side and another sheet of double-wall polycarbonate on the front side, then wrap the whole thing in fiber glass. There are tons of tutorial here, but stay tuned because I plan to do just this.
