Solar Thermally Pumped Hydroponic System
This is a small scale test system for the idea of using temperature differentials to operate a ebb and flow hydroponic system.
The theory behind it is the idea gas law PV=mRT. That is an increase in temperature in the gas trapped in the reservoir leads to an increase in volume of the gas.
Step 1Materials
A 2 liter bottle
a 1 liter bottle
caps
superglue
aquarium hose and fitting
black paint
tape
perlite
65 comments
1-40 of 65next »
Dec 22, 2010. 8:23 AMkomputernerd says:
PET water bottles and 2-liters are made as one time use plastics. They will leach harmful chemicals into your nutrient solution and ultimately your plant, especially at higher temps, and in direct sunlight. Experiments with PET for hydroponics should be kept to ornamental plants only.
Nice concept however. Although, when I grow with hydroponics, my plants like my nutrients to be around 60F degrees. Any temperatures warmer and you can experience less nutrients uptake by the plants, as well as bad bacteria growth in nutrients.
Dec 31, 2011. 10:24 PMmacrumpton says:
The concept should work equally well with metal or glass or even ceramic containers.
Dec 4, 2011. 3:37 PMfozzy13 says:
This is such a cool concept, and I never thought about it before. I might make one just because of the awesome solar-pump concept. It seems like it could have other applications. Thanks for posting : )
May 15, 2011. 11:46 PMautokymatic says:
Aren't light and algae on the roots problematic? Was it suggested to make an opaque shield for the 1L top planter?
Apr 20, 2011. 9:05 PMvampierwolf says:
Do you think you could put this in an enclosed system... like a terrarium?
Jan 27, 2011. 11:26 PMandycyca says:
Brilliant idea. I've never actually tried hydroponics, so I'm going to ask a few questions that may be obvious:
1. I noticed you drilled an extra hole to prevent overflow (nice!) but I'm concerned about the seedlings getting enough water/nutrients. Did you "bury" the seeds? Did they need additional water as seedlings?
2. (I may have misread) Which hose diameter did you use? I think that is relevant to this proyect, as it affects how "easily" the solution will go up and how much will actually be feeding the "pot"
3. During the day, how much time did you have water in the "pot"? Is it constantly going up and down? Does the water level change quickly?
4. You said your reservoir didn't needed refills for months. Does anyone know whether storing the nutrient solution affects their concentracion? I mean, theoretically speaking, the compounds won't react between themselves, but they may precipitate...
Nov 1, 2010. 3:30 PMseandogue says:
very smart idea. thank you!
Feb 11, 2009. 4:33 PMOUTATIME1290 says:
would this work inside a building under a grow light that's on a timer for an extended period of the day?
Jul 10, 2010. 9:09 AMdowngrade says:
Check out some other plans, if you are willing to use electricity on the lighting you shouldn't be too worried about using an air or water pump that you would need to make this work indoors.
Jan 23, 2009. 11:14 PMalex-sharetskiy says:
that's cool! is it better then planting straight into the ground and watering with nutrients?
Jul 10, 2010. 9:08 AMdowngrade says:
Actually it depends. On a farm you might be able to more efficiently grow a large crop load, but hydroponic grown plants usually have better nutrition as you control what goes into them. Granted someone planting in the soil could possibly control the nutrients to come up with a better plant, but it is unlikely, and nearly impossible on a large scale, but you can also mess up growing things with hydroponics... but then again this system, where as it works, isn't exactly precision based.
Feb 15, 2009. 9:30 PMspiderwolf says:
Haha I live in Idaho. It's rather easy to grow things here. Except our winters are cold and long as hell!
Jan 26, 2009. 7:49 AMalex-sharetskiy says:
alright i'll have to try this some day..
Jan 23, 2010. 8:22 PMCaptainsimon12 says:
Love the idea, and I'm considering making a larger-scale version at home. Can I suggest improvements?
1 - The base bottle probably softens up (however slightly) when heated. It would expand as the pressure inside builds. If a more rigid base container were used, one that (ideally) doesnt change at all, then the setup would probably be significantly more efficient.
2- If you were to somehow increase the surface area of the base container (providing a larger surface to face the sun) the effectiveness would also improve. I was thinking of soemthing along the lines of the fridge backing used in this Instructable: http://www.instructables.com/id/Solar-Thermal-Water-Heater-For-Less-Than-Five-Doll/. It is metal, and therefore absorbs the heat more effectively than a plastic bottle. Although.... it may cook the plants before they are fully grown.... Maybe if there were a resevoir between the base and the bottle with the plant in it that the water could cool in, but still maintain the pressure needed to keep the water moving....
Just a thought. This is a truly genius idea. Props.
Jul 10, 2010. 9:00 AMdowngrade says:
To your first point, it makes me wonder if you could find some ducting that would wrap around the bottle nearly perfectly.. the metal would heat up pretty good and if it was tight against the bottle stop it from expanding and instead push the water up more efficiently... If you got the ducting like that which is intended for connecting to a drier or something it isn't a full cylinder so you could do something like put large zip ties around it to hold it to the bottle I would think.
Mar 17, 2010. 11:00 AMwoodstockbirdy says:
 what is perlite?
Apr 25, 2009. 2:56 PMsimpkin says:
Great instructable, I just happened to have some spare plastic bottles laying around and grabbed some "Soaker hose" from home depot came in about 50 feet for 8$. I did a slightly modified version using 2 Gatorade bottles one small as the growing container, a large one as a reservoir and painted them both glossy white. Then a 2 Ltr soda bottle painted flat black with an additional hose to the top of the reservoir to provide solar pressure. I was amazed at how responsive this setup was to sunlight and clouds. Going to play with it a little more and soon hope to have many setup growing veggies. depending on our soda and Gatorade intake...
Apr 21, 2009. 12:47 AMDharq says:
I think if you paint the bottle white up to the water level in the lower bottle and the air filled section black, that should help keep the water cooler while still letting the air expand and contract as needed
Apr 20, 2009. 12:49 PMNaTeB1 says:
No offense intended, I do like the idea of using the sun to power anything but this system has some major flaws The nutrient solution will be way to hot and stagnate, which pretty much counters any advantages of using hydroponics How will the roots get moisture at night? Also you should consider shielding the grow site from sunlight as well to help keep algae from growing.
Apr 6, 2009. 11:35 PMhootie233 says:
wait wait wait, what are you guys saying should be done to fix this?
Apr 7, 2009. 6:42 AMhootie233 says:
sorry, thats what I meant, i know that this set up would get the job done, I'm pretty excited about it either way.
Mar 28, 2009. 5:19 PMagatornz says:
now that is cool. i am in to passive systems or should i say those that dont rely on electricity - and i like the look of this one - so how did the test go - has it panned out?
Mar 11, 2009. 9:40 AMjulesfl says:
Do you completely cut the bottom of the bottle off? How long is the tube going into the reservoir? Waiting for mine to work. Live in Fl, so should work. Awesome concept!
Feb 21, 2009. 9:34 AMkudoskun says:
A half-full 2L bottle will get warm enough to push the nutrient solution into the 1L bottle? Are you expecting the rainfall to make up for the rest of the capacity of the 2L? What if you live in Az, where rainfall is rare. Perhaps then fill the 2L reservoir to capacity?
Feb 11, 2009. 4:40 PMOUTATIME1290 says:
AND how did you start the seeds? did you just plant them in the perlite and let it be?
Jan 23, 2009. 7:11 AMOlyveoil says:
This Instructable is totally cool and one that I'm definitely going to try. It combines two things that I really love...science and gardening. Thanks for sharing.
Jan 23, 2009. 6:57 AMSixTwelve says:
What a cool idea! I wonder, though, if you're having any blow-back from heating the nutrient solution? Black plastic can get pretty hot in the sun, at least in my neck of the woods. Now that you've done the proof of concept, it wouldn't take much to heat the air and shelter the fluid. Or am I being a ninny?
Jan 23, 2009. 2:41 AMmatrix1984 says:
How often does the resevoir need refilling?
Jan 22, 2009. 4:58 PMDroose says:
Just a suggestion, but if you make the viewing strip even half as wide you'll increase the potential "energy capture" area by quite a bit. In this sort of system you want to try and maximize the amount of energy entering the system.
Jan 22, 2009. 10:40 AMchezman1 says:
looks interresting will 20/20/20 will work also instead of mircle grow
Jan 22, 2009. 4:51 AMLylec says:
Curious on the make up of the nutrient solution. What did you put in it?
1-40 of 65next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
248
Author:Tool Using Animal
I'm a graduate of the University of Central Florida with a degree in Mechanical Engineering, I am currently working on my Master's. Otherwise, I enjoy building things, designing the things I'm going ...
more »
