The theory behind it is the idea gas law PV=mRT. That is an increase in temperature in the gas trapped in the reservoir leads to an increase in volume of the gas.
Remove these ads by
Signing UpStep 1Materials
a 1 liter bottle
caps
superglue
aquarium hose and fitting
black paint
tape
perlite
And why isnt this in the bottle contest then??? ;)
Nice idea of s imple principle. Well made and coo output.
Nice concept however. Although, when I grow with hydroponics, my plants like my nutrients to be around 60F degrees. Any temperatures warmer and you can experience less nutrients uptake by the plants, as well as bad bacteria growth in nutrients.
1. I noticed you drilled an extra hole to prevent overflow (nice!) but I'm concerned about the seedlings getting enough water/nutrients. Did you "bury" the seeds? Did they need additional water as seedlings?
2. (I may have misread) Which hose diameter did you use? I think that is relevant to this proyect, as it affects how "easily" the solution will go up and how much will actually be feeding the "pot"
3. During the day, how much time did you have water in the "pot"? Is it constantly going up and down? Does the water level change quickly?
4. You said your reservoir didn't needed refills for months. Does anyone know whether storing the nutrient solution affects their concentracion? I mean, theoretically speaking, the compounds won't react between themselves, but they may precipitate...
1 - The base bottle probably softens up (however slightly) when heated. It would expand as the pressure inside builds. If a more rigid base container were used, one that (ideally) doesnt change at all, then the setup would probably be significantly more efficient.
2- If you were to somehow increase the surface area of the base container (providing a larger surface to face the sun) the effectiveness would also improve. I was thinking of soemthing along the lines of the fridge backing used in this Instructable: http://www.instructables.com/id/Solar-Thermal-Water-Heater-For-Less-Than-Five-Doll/. It is metal, and therefore absorbs the heat more effectively than a plastic bottle. Although.... it may cook the plants before they are fully grown.... Maybe if there were a resevoir between the base and the bottle with the plant in it that the water could cool in, but still maintain the pressure needed to keep the water moving....
Just a thought. This is a truly genius idea. Props.
