loading
Step 4: Connect the Toggle Switch
  1. Grab the twisted together negative (-) wires from the battery pack/ solar cell. Solder this to the middle pin on your toggle switch.
  2. Take the last 6 inch piece of wire and solder it to either one of the remaining outside pins. It doesn't matter which one.
Tip: If you can't thread the wire through the little holes on the Toggle Pins don't worry. Using a Helping Hand you can easily solder to the side of the pins.
Keep in mind that the toggle switch is made of metal and plastic. It is possible to melt it if you hold your soldering iron in place too long.
<p>Didn't work at all, waste of $40</p>
<p>I live in Tokyo, and I need to buy the USB Charing Circuit Board but I can't find it! I need it because I'm doing this project for my Science Fair. So does anyone know any shops in Tokyo which has this? Please help! I would love to buy it from the website but it would take 7-10 days, which exceeds my time limit! Pleasee help!!</p>
<p>Is it possible to replace the batteries with supercapacitors? i heard they charge up faster.</p>
I made one that was this, then I am currently, soldering 5 seconds ago, making one that also has a crank charge too :). the advancement abilities to your project here are amazing and easy as pie.
<p>If you added more batteries ie. enough to make it to 5 volts would it still charge on apple devices</p>
I realIy liked your project idea :) . So I wanted to ask if you can charge the phone battery when you have your solar panel and the batteries connected/active? Or can you only firstly charge AA batteries with your solar panel then turn off the solar panel and then charge phone battery from AA batteries?<br><br>If you can have all the components active at the same moment wount the solar panels 6v be too much for the charging circuit? The charging circuit can take voltage between ~2,6v and ~4,8v ( correct me if I'm wrong) . Would using a solar panel with lower voltage but with higher amperage solve this for example?
<p>Hi, I just finished making the Solar USB charger and put in a new pack of rechargeable batteries. But when I charged it into my iphone 5s, it could only charge for about 7% before the small coil on the <a href="http://www.browndoggadgets.com/collections/charge-controllers" rel="nofollow">DC to DC Boosting Circuit with 5V USB Output</a> (the red one not the Apple one) started to get really hot and made very weird noises. Does anyone know whats wrong with it? I checked my wiring and it doesn't seem to be wrong to have caused a short. Any suggestions?</p>
Will this charger work with an iPhone 6?
<p>I am using a 4.7V, 500mW, 120mA solar panel. This is supplying three 1.2V(x3=3.6V), 2100mAh AA batteries through a 1N914 diode. The output of my battery pack is supplying a DC-DC boosting circuit with USB output. I am getting an output of 5V. But when I connect my phone to the USB port, the charge percentage goes down. What can I do about it? Is my current or power not enough?</p>
<p>how many amps does the apple circuit produce</p>
<p>also, when i charged my iphone with the apple circuit, it didnt charge. But when i used my android, it worked BUT it only showed that its charging but the battery actually went down, please help</p>
<p>Make sure your batteries are all charged up. Also, some phones draw more power than the USB circuit puts out. They are CHARGING but their percentage goes down since they're using more power than you're putting in.</p>
<p>Does this work for iphone5 also because its a USB?</p>
<p>Yes.</p>
How did you make the board? Can I ask for a guide? Sorry im new
<p>hi, i was wondering what are the dimensions for the laser cut box. If you can reply, thanks</p>
While it is off does it still charge the battery
Awesome! Looks like the ghostbusters ghost trap; ) we need more solar stuff! more more!
<p>We're working on it!</p>
If i wanted to buy one of these could i purchase one from you?
<p>Thats the idea. We have kits, and we highly recommend you building one on your own. It was designed for middle school students to learn how to solder with.</p>
<p>so i have 4x 1.2v (= 4.8v)solar panels from those yard lights you buy from walmart they suck as lights but they come with a solar cell and rechargeable batteries so it can last all night (they dont) so im using them would they work or since you need 5v do i need to add another</p>
<p>each of my solar cells puts out 2.2v +- 0.2v so with the 4 i get 9v</p><p>so do i need all 4 and all 4 batteries or can i can i do with the 3 like you</p><p>oh by the way my batteries are the 2/3 aa the weird short ones but normal sized around </p>
<p>The big issue isn't the voltage, it's the amperage. Thats what will determine how fast things charge up. Typically the ones out of garden lights are super low amperage. You'll be waiting weeks to charge up the internal batteries.</p>
I like the bleach wallpaper on the phone in the pictures
<p>Ha, not my phone!</p>
Thank you for share your project. I think you will be right to use a boost up from the Solar power to the USB. Anyway, you use the diode to drop the voltage from the solar power to the battery and not to let the current flow from the battery to the solar power, isn't it ?
<p>It's to prevent the solar cell from sucking power from the battery, which would destroy the solar cell.</p>
<p>Do I have to use this 1N914 diod, or can I use (nearly) any other? Go some electrical waste here..<br>What do I have to care when choosing the diod?</p>
<p>Pretty much. 1N914 is super common and cheap, and has a low voltage drop. Thats why we use it for a lot of our projects.</p>
<p>Great instructable and a fun build. The only mods I made were hot glueing the battery holder, USB connection and solar panel on.</p>
<p>Hot glue is the way to go. Looks nice.</p>
Or anyone if they could answer
I promise I am not a narc
Hey guys i need to know ASAP... I have created my own model of solar charger, i have searched up the patents on solar chargers and Tsann Kuen Enterprise Co Ltd seems to hold a patent for solar chargers have you guys received any threats since you sell your products?
<p>they just say this charger is not recognized and then charge anyways or atleast thats what mine did</p>
<p>How long should it take to charge? I left it in the window for about a week and it charged my phone (galaxy s3) for maybe 5 minutes before cutting out . While it isn't super sunny out, I expected a little more. Is that normal?</p>
<p>Depends on many things. I've found that Galaxy S3 phones are tough to charge due to the fact they want 1A or more of power, plus they have huge batteries. For those phones you really need to use a Lithium Battery instead of AAs (plus the right protection on it).</p>
Instead of foam two sided tape, i used a hot glue gun
<p>Yup, that works just fine as well. Hot Glue is not conductive, though it is a tad messy.</p>
<p>Would a DPDT center off toggle switch work? If so, are there pros and cons? </p>
<p>Thanks for putting this together! Can you please tell me what the the voltage across the USB pins before hitting the voltage booster would be? </p>
<p>Hi, if I used a 12v lead acid battery would it be necessary to use a charge controller? How many AHR would be sufficient?</p><p>Thanks</p>
<p>You'd want to build a much much bigger setup if you were using a 12V Lead Acid. You'd want a big old 12V charge controller and a big 12V solar cell (18V actually).</p>
<p>Would i do any changes if i do it for charging an Iphone 5?</p>
that's understandable, but in my case I need something lightweight and easy to pack around so its perfect, but to each his own.
<p>They're just limited in size and metal. A small plastic container would work far better and be far easier to waterproof.</p>
if i change the battery with battery size D 1.5v and 6000mAH. solar charge still works?
You need to have rechargeable D batteries, regular ones won't recharge. If you have rechargeable ones it would work just the same, only it would take a much longer time to charge up as their capacity is greater than AAs.
About This Instructable
260,089views
3,158favorites
License:
Bio: I used to teach middle school science, but now I run my own online educational science website. I spend my days designing new projects for ... More »
More by BrownDogGadgets:LED Broken Heart Bracelet LED Paper Holiday Tree Red LED Nosed Reindeer
Add instructable to:
