I know there are other instructables about USB flashlights. I got the idea reading this one when I saw how similar the circuits were. This is the only solar and USB one I know of though. I do not want anyone thinking I copied this idea.
DISCLAIMER: I AM NOT RESPONSIBLE IF YOU FRY YOUR LED LIGHTS, YOUR USB PORT, SET YOURSELF ON FIRE OR KILL YOURSELF (SOMEHOW). WHAT YOU O WITH THIS INFO IS NOT MY FAULT. YOU HAVE BEEN WARNED.
Remove these ads by
Signing UpStep 1Materials
- One solar LED flashlight (these are widely available for about $1 on ebay. This is where mine came from)
- Male A USB cable (these can be cut from almost and USB cable)
-two resistors (1/4 watt), my LED light's battery was rated at 3.6v, so a 3 K ohm and a 4k ohm would probably be ideal. I could not find these so I substituted. My resistors only gave me 3 volts, and now my LEDs are dim when USB charged
-misc.: wire, solder, soldering iron, pliers, wire cutters, side cutters, dremel (optional), shrink wrap (optional, but recommended), and other hand tools may come in handy
Here's what you're missing though.
That is PERFECT for modding!
Once the batteries die, You have a project case, a couple LED's, a solar cell, and motivation to make it work! :-) That's over half the battle. All that's left wanting is a rechargeable battery, MAYBE a current limiting resistor for driving the leds, and a minimal charging circuit for your battery.
Being a bit wonky doesn't make things unsuitable for hacking, it makes the hack more interesting!
