Anyway, I wasn't too keen on losing the view or light so I set my mind to wandering and came up with the idea of using poly film instead of plywood. The first prototype was made using poly film and the initial test gave me 90 - 94 deg. with the sunlight hitting about 60% of the window screen. Not bad. OK. Now, how can I improve this? If I can reflect the sunlight onto the backside of the screen, it should generate more heat. Aluminum foil? You would need a substrate to attach it to and it would also eliminate the view and light. Then it hit me! Aluminized Mylar (emergency blanket, rescue blanket etc.)!! I recalled that as I was playing with other solar projects that these blankets reflect light and heat yet are also semi transparent, so I tried it. Super! It is like having polarized windows and it boosted the output temperature about 4 deg. This winter will tell the tale.
Now, on with the instructions...
What you need:
3/4" square molding for basic framework
Black window screen - the window screen I see around here isn't really black but Charcoal. Still dark enough to serve as solar absorber.
1/4" X 3/4" molding for attaching film to frame, screen bead molding?
Saw - table saw or miter box
Drill motor
Screwdriver or power driver
wood glue - optional
a sharp utility knife to trim excess film
heavy duty scissors or tin snips for cutting window screen - you might also consider gloves when working with aluminum screen
#6 X 1-1/2" wood screws - I used 8 per frame
#6 X 3/4" wood screws for attaching trim molding
countersinking drill bit for the above screws
Staple gun and staples - 1/4" - 3/8"
POly drop cloth, emergency blanket or other transparent sheet to enclose air chamber and for anti siphon flap valve. Another option that may improve efficiency would be a thin polycarbonate sheet screwed to the frame.
Remove these ads by
Signing UpStep 1Build the frame
assemble the top and bottom rails to the ends of the upright rails using one #6 X 1-1/2" wood screw at each joint. Here is where we might add wood glue for a more durable joint. Make sure your frame is relatively square and fits well into your opening. Not too tight and not too loose. A competent woodworker might dado the frames for a more professional look.
Now, add the inner rails that will create your inlet/outlet openings. Considering my window size and emergency blanket size (52" X 84") if I make the inner opening 50-1/2" high, I can use the 52" width of the blanket with minimal waste. That makes my vent openings 2-3/4" high by the width of the frame. There is a formula for determining the vent size but me and formulas don't get along too well. Some percentage of total collector area.
Now you might paint or stain your frame if desired.
Is it possible for everyone, including the practicalists and the thermodynamicists to be right? I think it is.
First of all, it is obvious that putting up a solar panel is not going to cause any more light (and therefore heat) to come into a room. As was pointed out, that is controlled by the size of the window. As was also pointed out, all that light bouncing around the room is being absorbed by carpet, furniture, your bobblehead collection, etc.
The thing is, neither the carpet nor the chair is a very good re-radiator of heat and so the chair feels nice and warm if you sit in it because of CONDUCTION and the carpet feels warm (if you have your shoes off) because of CONDUCTION, not radiation.
In another vein, folks usually keep their windows covered with drapes in cold weather to reduce heat loss through CONDUCTION, unless they have double or triple pane windows in which case they might not need a solar panel in the first place. The other reason for closing the drapes is so that UV rays don't discolor or rot the chair fabric (or fade the bobbleheads).
Thermodynamics aside, thebriguy did the one thing the body can relate to. He heated the air. Therefore, with the solar panel installed, while the furnishings
might not be warm, the air is, and that makes people in the room feel warmer as well. And, not to be taken lightly, the solar panel probably keeps some room heat from being conducted outdoors through the glass.
I think we could all be happier if we agreed that thebriguy's panel does not make the absolute room temperature any hotter, but it does convert the available heat energy into a form that the human body likes best. AHHHH, pass sthe hot chocolate.
IS there any laws against it? zonning etc. Since bushes will hide it from plain view from a far?
or I can only have one in a trailer park like I hear mostly?
thanks a lot.
Al Boz
Budd
I live i a mobile home as well, and these are not built as "houses". The gas pipes are right under your floor, and although the homes are built to have 'give', gas pipes aren't.... So you may have small gas leaks and not even be aware.
Just be careful.
Fantastic idea, though!
Good work, sir !
Since I have such a snug fit in the window frame, I decided to cover the insert's exterior facing frame with the clear heat shrink window covering kit. I believe it increased the efficiency considerably, as it is heating just the existing room air and not the cold window air. Just the other morning, at 10:00 am, the outside temp. was in the low 40's and I was getting 96 deg. out of the window insert, while getting 84 deg. from the external solar panel. I have noted 110 deg. from the insert from earlier observations. At that time, the external panel was contributing 180 deg. to my bedroom and the room temp reached 75 deg. (heaven). I have a really low tolerance for cold temps.
I read in a review on some DIY solar panel guides that they use awesome examples but that in fact this is nonsense.
Here is where the reviews are: http://energy.e-bookz.info
Anyone an opinion?
As some said, there are two different things :
the amount of "heat" (energy)
the temperature of the different elements of the room (air, walls, floor)
For those who are not trained in thermodynamics, it is easy to understand the difference.
Compare energy-heat with a VOLUME of liquid in a bucket (say 3 litres)
and compare temperature with the LEVEL OF WATER in this bucket (say 6 cm).
If you take another bucket (smaller in diameter) and put your 3 litres in it, the height of liquid (temperature) will be higher.
This is why it takes longer to heat metal (large diameter bucket) than plastic. It will take more heat to reach the same temperature.
In the case of this instructables, people are talking about 10° increase in room temperature. This is in fact air temperature. If they check the walls, they may find a much lower temperature. Air temperature is the real measure of "how good we feel", but it is a wrong measure of "how warm is the full room with walls and floors".
I think what is happening is when you don't have the screen, you heat walls and floor. The concrete needs a lot of heat to warm up, so the light coming directly from the window does not heat air and doeas not increase much the concrete temperature.
With the screen the heat entering the room is first CONCENTRATED in the air. It is logical that a (air) temperature increase be registered and that occupants feel better.
Of course, the air will then heat walls and ceiling (remember, hot air goes up), so the net effect is physically zero. But as the nervous system of occupants is concerned, they will feel better, as long as they don't touch walls and floor.
Thus you could save pennies per month in your energy bills by retaining a bit more solar heat - and you would also feel the noticeable stream of warm air which would convince many people it is functioning much better than it actually is.
Of course, the solar inserts in this Instructable would have next to no impact on said retention; in fact it will likely lessen the retention and reflect out more heat than you had before, as it has no proper chamber to heat the air or circulation of said heated air.
You probably know this already and are simplifying to get your point across; but if you explain where the myth/misinformation is rooted, people are much more likely to both believe, and more importantly, understand.
In essence there are two air chambers in these inserts one between the window and the insert, and another between the screen and mylar film. The cooler air enters at the bottom and weaves through the screen on its way up and out the top vent. I don't have a suitable graphics program to create a diagram of the process, but if you check out the "Solar Barn" at Home Power.com, there is a good explanation of the thermo siphon process.
just as a side note sitting in yard not attached to anything ,snow and ice on the ground ,i recorded tempt with a digital temp. at 70 degrees it was 22 degrees outside at the time
I don't doubt that the device makes the area around the window more comfortable (and usually that's the draftiest and most uncomfortable part, so that is a big advantage) but the net effect on the average temperature in the room (and the heating bill) is the same. The heat is just being caught on the device instead of the floor or drapes or what-have-you.
I feel your pain :p One of the more confusing bits is that somewhere along the line, schools stopped teaching that there's a difference between heat and temperature. I think that's what's going on here.
And, I support your post :)
The amount of heat entering isn't changing. What is changing is the what is being heated. Instead of adding heat to concrete (for example) , we're adding heat to this screen. Concrete has a much higher specific heat capacity than this screen.
I'm not saying you can't thermo siphon air like this (I don't think anyone is claiming that) - but what you can't do is bring more heat into the room. Your heat source is the sun - which has (for our purposes) a fairly constant output. Our heat collector is this window, which has constant dimensions. Adding something behind the window does not somehow increase the amount of solar output.
People quoting 'Laws' and reasons why peoples work
Oh please - you're the only one dropping thermo laws. I think the words you're looking for are heat flux:
http://en.wikipedia.org/wiki/Heat_flux
