Introduction: Solar Charger
Hi,
In this step-by-step guide i'm about to teach you how to design and build a simple solar charger.
What you'll need:
1) Solar panel.
2) Adjustable Boost Converter Charger Module.
3) Electrical Wires.
4) USB female cable.
5) A box.
6) Recommended - portable USB charger, a cord, led.
7) Soldering Tin.
8) Duct tape.
Tools:
1) Plier.
2) Soldering iron.
3) Hot glue gun.
4) A knife.
5) Tweezers.
6) Voltmeter.
What you'll need:
1) Solar panel.
5) A box.
7) Soldering Tin.
8) Duct tape.
Tools:
1) Plier.
2) Soldering iron.
3) Hot glue gun.
4) A knife.
5) Tweezers.
6) Voltmeter.
Step 1: Attaching Wires to the Panel
Solder electrical wires to the solar panel (Red to +, black to -).
Cover it with the duct tape.
Step 2: Adjusting
Connect a power source to the charger module and a voltmeter to the output of it. Now adjust the module to 5v output.
connect the panel to the module (to the input).
Step 3: Connecting USB
Cut the USB cable and then solder the + cable to the + output in the module and the - cable to the - output.
Step 4:
Mark on the top of the box the size of the solar panel.
Cut near the borders that you've marked so the hole is a bit smaller than the panel.
Step 5:
Use hot glue to glue the panel to the hole.
Now glue the other parts to the bottom of the box so they wont move, in the side make a hole as big as the USB cable.
* I recommend gluing the USB output well so sand and dirt wont come in.
**If you had cotton wool in the box i recommend putting it between the panel and the bottom it will also help preventing the parts moving.
Step 6: Finished!!
Now you can test your charger.
Step 7: Recommended Additions
* If you like to you can add a led to the module output so you'll know when its working.
** If your box is big enough you can add a portable charger instead of the USB output so power wont be wasted, that way you'll be able to use it even when the solar panel is not exposed to light.
*** I added a small loop to the side of the box so i will be able to hang the charger when driving the car, going on camping etc.
