3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solar charging e-reader.
Hi, I made this instructable to show how to add some solar cells to your e-reader, so that you will never need to charge it again.
Update: I replaced the Schottky diode with a MAX1555 Li-Ion cell charging IC. Thanks go to moldboy and Kohaku for their input on making the charging circuit safer.
What you need :
  • An e-reader,  I use a first gen Kobo, but I'm sure this is also possible with any other.
  • Some solar panels,  like these. Perfect size and voltage and decent power too.
  • A Schottky diode , you can get this at any shop that sells electronic parts. You need a diode to prevent discharge of the battery. The advantage of using a Schottky diode is the lower voltage drop.
  • A MAX1551 or MAX1555 IC. They operate with no external FETs or diodes, and accept operating input voltages up to 7V, so very easy to implement. Here is a datasheet. I ordered a sample from the manufacturer.
  • A SOT23 to DIP breakout board. You need this, because it's quite hard to solder wires directly to the MAX1551/1555, since it's so small. I got this from eBay.
  • A small capacitor, to make life a little easier for our MAX1551/1555. I used a ceramic one I had laying around.
  • Some wires, a soldering iron, solder, a dremel and padded double sided tape. A multi-meter can also come in handy.
Here are some minor technical details:
This e-reader (as most of them are) is powered by a 3.7V li-ion polymer battery. These kinds of batteries need pretty tricky charging curves: fast at first and trickle charge till full, then the current stops, since over charging can be dangerous. For this reason I replaced the Schottky diode I used before with a MAX1555 charging IC. A Schottky diode also works, but it can damage the battery in certain circumstances.
The specifications of these solar panels claim that they can do 80mA, but after some measurements I came to the conclusion that in reality they will only reach about 50mA. Adding the two panels together we come to 100mA. This means that they should be able to charge the battery from nothing to full in about 10 hours. However, the charging current is controlled by an IC and will be lower during the later half of the charging cycle.
Step 1Taking apart the e-reader.
The first step is to open the e-reader, but since it is not held together with screws, this can get kind of tricky. What I did was to take a knife and pry it in between the two halves of the casing at a corner. After this came apart, I worked it all the way around the entire device until it came apart. Watch out for the double-sided tape that is between the top cover and the screen.
Detach the battery wires from the main board and remove the battery.
Remove the four screws and carefully lift the PCB with attached screen from the rear panel. There is also some clear plastic behind the main board, don't lose this.
45 comments
1-40 of 45next »
Sep 7, 2011. 10:37 AMbitbangr says:
I have a thought....Amazon makes a cover for the Kindle 3 that connects to the battery to allow you to power a built-in light. I wonder if you could tap into that and build all the goodness into the cover, avoiding opening the reader at all.
Aug 4, 2011. 11:57 AMlhospadaruk says:
Why not just wire the solar panel to the USB power and let the built-in charging hardware handle things?
Sep 7, 2011. 7:12 AMlhospadaruk says:
That's definately true, I thought at first that maybe it only goes to usb mode when it can actually talk to a usb host, not just when it gets usb power, but that's not the case.
Sep 6, 2011. 3:37 PMksilverwing says:
In that case, couldn't you just have some kind of cover on the solar panels so that they're in the dark while you're using the ereader, and then you open the cover when you want to charge it?
Sep 6, 2011. 2:32 PMewookie says:
i don't think he intended to leave it plugged in...just when charging. it is stupidly inefficient that these type devices turn themselves on when you plug them in to charge.
Sep 7, 2011. 12:02 AMSatka says:
Thanks for this great instructable, very clear and detailed.
It make me want to solar power more things now :)
Aug 5, 2011. 4:10 AMclark981 says:
Ya You're right. Besides, the nook's internals are under a grey panel, and are WAY MORE complicated than Kobo's, and I would go to juvy if B&N found out I totally hacked my nook. Oh Well.
Aug 3, 2011. 6:29 AMclark981 says:
Does it work with nook 1st edition, because i dont want to ruin my nook. I save up all my birthday money and allowance to buy it myself.
Jul 3, 2011. 3:14 PMstakahashi says:
I really like how professional this turned out. The only downside I see is that you have to leave your e-reader out in the hot sun. I could never do that to my beautiful kindle.
Jul 2, 2011. 6:28 AMjeoncs says:
Awesome job this is epic for any e-ink based reader since they use so little battery. For people afraid of voiding a warranty it wouldn't be too much effort to get one of the cheap silicone skins and a usb cable to stick to it too.
Jun 15, 2011. 10:42 AMKohaku says:
i would look at replacing the Schottky diode with a MAX1551 IC which is designed to safely charge lithium cells.
Jun 15, 2011. 12:14 PMmoldboy says:
Yeah that would be better than the method I described. The other thing you might look at doing is simply connecting the the power and ground to the USB port as it provides the charging circuit through a MAX1551 or similar. The only problem would be having the USB and solar connected at the same time, so be sure to still include the Schottky and probably only plug in USB with the device on its back.
It would be possible to cut a trace and add an inline diode to the USB as well but that might cause a voltage drop and prevent the charger from working. (Though it could be specified at 4.5V and USB is typicaly 5 so a 0.3 drop diod would be doable as well. I have a kindle not a kobo so I can't say for sure how easy that would be. You may have to use surface mount parts to make everything fit better, but there isn't any challenge there. In fact you can probably find a dual Schottky diode in a small SOT package that would allow you to separate the USB and Solar but still have them both power the charger circuit.
Jun 16, 2011. 7:16 AMbobgdolly says:
Could you make this work using normal charging port ? without opening the unit .
Jun 17, 2011. 6:08 AMbobgdolly says:
The Kobo has a separate mini rca charging port, it cannot be charged thru the usb .
Jun 17, 2011. 3:01 PMbobgdolly says:
Your wrong ! I plug the trans. in to the wall the other goes into the charging port NOT THE USB!!!!!!
Jun 18, 2011. 7:28 AMbobgdolly says:
Thats what you have , I must have a earlier version, mine does have two ports one usb one charging, Would you know if I could do the solar thru the charging port ? and can you let me know how to do it ? Thanks for all your time.
Bob
Jun 20, 2011. 6:16 AMbobgdolly says:
Thanks for your your input, I thought that might be the solution , the reader is a Kobo Literati, I have a Nook that I use more often but I use the Literati for nighttime reading because it's back lit. I think I'll make a solar charger with batteries to extend the reading time. Thanks again. Bob
Jun 17, 2011. 12:56 AMGocho says:
Nice Job!
I can't wait to see the improved version with the circuit to save the battery.
How many lifetime would have the Solar Cells?
Is not detailed in the DX web. Maybe in the attached docs.
Jun 17, 2011. 2:34 AMGocho says:
Good point :)
Jun 16, 2011. 4:34 PMdark sponge says:
Great concept, really similar to my solar DS. After making that, I realized how it was actually bad for the battery and potentially dangerous. You can add a charge protection circuit (I have a link in the materials list of the updated version) for really cheap and save the battery and a potential disaster, especially with your solar cell at 5.5 volts. The updated version is here:
http://www.instructables.com/id/Solar-DS-quotLightquot-Redone-and-Greatly-Impr/
I don't want to seem like a spammer, I just want to prevent a battery disaster :-)
Jun 16, 2011. 3:14 PMbojopopo says:
great design! looks awesome, just got new kindle, so wont be gutting it just yet, but its fun to think about haha!
Jun 16, 2011. 9:37 AMeandresen says:
That battery looks like a LiPo
Jun 16, 2011. 9:16 AMilluminatis says:
Aren't you worried about cracking the LCD by leaving out in the sun?
Jun 16, 2011. 9:38 AMAnidion says:
Most e-readers have an electronic ink screen, which is ink that is arranged electronically into letters or numbers or whatever.
Jun 16, 2011. 8:03 AMsqeeek says:
I've done something similar with an old Palm. The easiest way for me to do it was to wire the power source (solar/batteries/whatever) to the 5v part of a USB cable, then hook a USB female side to the other two, magnet that on the side...
Then when I want to hook up my Palm to my computer, I plug it straight into the computer or USB extension cord. Don't have to worry about discharge, and don't have to remember to bring my USB cord anywhere :)
Cool instructable.
Jun 15, 2011. 11:42 PMalison201102 says:
Looks good,but how to use it still not understand...
Jun 15, 2011. 6:40 AMmoldboy says:
I would advise that no one do this to their ereader if they like it. This is a 100% guaranteed way to destroy the battery.
Li-ion batteries have a maximum cell voltage of 4.1 or 4.2 volts. Anything more than this and you cause serious long term damage to the battery. The proper li-ion charge cycle starts off with a continuous current charge mode, that is at less than 4.2 (or 4.1) volts a constant current is supplied to the battery. Again anything more than 4.2 V and you damage the battery. The current is not too important as long as you don't exceed the battery maximum. After some time the the battery voltage will rise, when the battery voltage rises to 4.2 volts the charge mode switches to constant voltage mode. That is to maintain the 4.2 volts the charge current has to decrease. The charger will continue to charge the battery with a decreasing current until some predetermined cutoff point, usually <10% of the charging current. There is then, in some cases, a trickle charge state that keeps the battery full. Depending on the battery this isn't always advisable.
What this design does is supply a voltage of around 4.5 - 5.3 volts (depending on the panel and diode) at a random current, which is going to destroy the battery. Some batteries like being trickle charged (like car batteries) li-ion batteries do not.
1-40 of 45next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:flapke
