Step 5Soldering the MAX1551/1555 to the breakout board.
You can follow this guide, but I'll summarize here:
Place a small amount of solder on each of the pads (the guide linked above does this a bit differently).
Place the IC with a pair of tweezers or a small clamp on the board and solder one of the legs.
Gently put a little pressure on the IC and heat all the legs so that solder will flow between the board and the legs.
- After letting it cool for a second, we can check the connections by measuring the resistance between the IC leg and the soldering holes in the board.
Add Comment
