I wanted to preheat water with solar energy before it went to my electric tankless water heater. The higher the temperature of the water going into the heater, the less electricity will be used to bring the water up to the preset temperature on the heater = money saved and it's Green!
First I re-installed my old 40 gallon gas-fired tank-type water heater. It is not even hooked to the gas line, it will just be a holding tank for the preheated water. I plumbed it so that the supply water comes into it first and then goes to the tankless heater. I'll get some more use out of it and it won't have to go see Mr. Recycler yet.
I installed a new pressure relief valve on it for safety. I popped off the plastic drain valve at the bottom of the tank and installed a steel nipple which then adapts to cpvc. That will be the cold water feed to the solar collector. Then I installed a "T" in the copper pipe between the output of the holding tank and input of the tankless heater. That is the warm water return from the collector. Don't worry about envisioning those connections right now... they will be obvious when you get to the "step 6" page.
Then, I threw together a "hot box" out of 2"x4"s and a piece of particle board. I made it to the dimensions of an aluminum framed window pane I had. I just used 3" drywall screws to hold the 2"x4"s together and 1-1/4" drywall screws to put the back on. I used a lot of silicon caulk to make it as air and water tight as possible. Painted it flat black and plumbed it with 1/2" cpvc. Then I painted the cpvc black too.
I don't know why I used this zig-zag configuration. I just started building and this was what I ended up with. I sometimes do things like that. It didn't occur to me until later that most of the solar collection boxes I see use a manifold across the bottom with several vertical tubes going up to another manifold at the top. Probably more efficient. But I'm sure this box will not be the one I keep. It was just a proof-of-concept quick-and-dirty.
Sorry about the fuzzy picture... the rest are better.
Remove these ads by
Signing UpStep 1Up goes the temperature!
Quick and dirty or not, it does a fine job of capturing the heat. I lifted the glass and took a reading and was surprised to find a 100 degree temperature rise!
( Nit pickers... notice the Max reading in the second picture...lol )
I've been toying with the idea of augmenting my current heating system with a solar hot water heater for some time now and have been wondering how I might make it happen.
I have an indirect system where a loop from my boiler goes into tank to heat the water. My boiler is about 85% efficient, and I'd love to improve that efficiency using solar.
Your project confirms several ideas I've been thinking about, so given time, money and materials, I just may be able to implement something.
Keep up the good work!
Unkel
Thanks for this instructable. Really inspiring :)
One thought: you might want to stress the fact that it is really important for anyone who wants to build a similar setup to keep the 'old' heating ON (either tank or tankless) and not be tempted to switch it OFF (or set it to a low temperature) and only use solar heated water. The warm water that reaches you shower must always have been heated to at least 60°C/140°F (!) to prevent the possible build-up of Legionella in the holding tank getting into your longs while showering.
And one question: what are your thoughts on leaving this collection box outside and connected during the winter in areas where it can freeze up to -20°C? Will ice in the pipes rupture them and cause big leakage or do you think the mass of the relatively warm water in the holding tank inside, by way of natural heat exchange through the water pipes (read: heat loss) prevent the still water in the pipes outside from freezing up?
Thanks for your thoughts!
In my travels through Asia I saw water heated everywhere solely by solar, and Legionella was never an issue.
So then the question is in what environment, in terms of temperature only (since there will be hardly any competition), the Legionella bacteria will thrive. The article on Wikipedia I referred to, confirms what I have been told about the subject: they thrive between 25 and 50 degrees Celcius but will be killed when the water reaches a temperature of about 60 degrees.
All cases of Legionella poisoning I have heard/read about involve three things: (1) water with a temperature within the correct range, that (2) has been still for long enough to let the bacteria propagate plus (3) a shower, garden sprinkler, fire hose, or fountain that sprays that water around so the bacteria can get airborne (living in tiny droplets) and reach fragile long tissue. Given these conditions, infection is likely.
Maybe the solar heated water in India is never used in showers with shower heads that spray fine enough droplets, or the water usually reaches above 60 degrees C, or the tanks are never so big that they keep water long enough to let Legionella build up...
About Legionella and chlorine: I understand (but am no expert on the subject) that the little critters are more resistant to chlorine than most other contaminants. Found a study on the subject on http://www.pubmedcentral.nih.gov/articlerender.fcgi?artid=239530 that might tell a more learned mind what the risk are. Obviously, the level of chlorination of your city tap water needs to be considered. Apart from that, it looks like they found that chlorinated water of a higher temperature (in the study 35 C which would normally be perfect for survival) Legionella dies quicker than in chlorinated water of lower temp (4C and 21C in the study)... So by your preheating method you seem to be actually reducing the risk of Legionella! If that is a correct in deduction of course... ;)
Sadly (in this respect) I am using non chlorinated water so by preheating, I am increasing the risk. By ensuring that my electric boiler tank always raises the water temperature well above 60C, I should be fine... I suppose this last stage heating (reaching over 60C) on night current only will be enough. Electric heating is relatively expensive so I would like to keep it limited to the reduced price of night time consumption.
About the freezing risk problem: I found a company in the UK, SolarTwin, that actually sells a somewhat similar system. The company claims their collectors do not need draining in winter since the pipes are made of some silicone rubber that can withstand expansion from freezing water. As soon as the sun comes back, the water will melt again and the system will be back functioning like before. As far as I can tell, their collector is designed for low pressure water systems, not high pressure city water... Maybe that allows for the use of more flexible tubes in the collector. I wonder how rigorous tubes must be for high water pressure and still be flexible enough to withstand 4% expansion when the water inside it freezes up. And if at all possible, what kind of tubes/material would suit the job.
Any thoughts on this last missing piece in the puzzle? If that is tackled, there would be no need for any heat exchange / antifreeze type solutions which would make it so much more expensive and difficult to install
Allard
I just read about one design that uses a heat exchanger from a discarded refrigerator (My refrigerator manual calls it "condenser"). It was advised to get a professional to first remove the freon or whatever is inside nowadays.
This idea is on this site as well but he used pvc pipe so it would work alot better with those nice copper pipes.
There are other places you can place the sensors for In-Line trackers.
Very close to the mirror is the best place. It looks at the sun back through the mirror and attempts to keep the sun in the center of the mirror. When working it is stable.
However, there is another stable position. This is when the suns image is anyplace on the edge of the mirror.
There is another tracker type called the "Receiver Axis", or "Target Axis" tracking mount. It's a bit more complicated to describe. See:
http://www.redrok.com/heliolighting.htm#receiveraxis
The main advantage is it can't get confused because the tracker is always aimed directly at the sun. It is mounted on a small mechanical gear mechanism.
Duane
Home of the $35 Solar Tracker Receiver
http://www.redrok.com/led3xassm.htm [*]
Powered by \ \ \ //|
Thermonuclear Solar Energy from the Sun / |
Energy (the SUN) \ \ \ / / |
Red Rock Energy \ \ / / |
Duane C. Johnson Designer \ \ / \ / |
1825 Florence St Heliostat,Control,& Mounts |
White Bear Lake, Minnesota === \ / \ |
USA 55110-3364 === \ |
(651)426-4766 use Courier New Font \ |
redrok@redrok.com (my email: address) \ |
http://www.redrok.com (Web site) ===
This is my system been running for about 6 weeks. hottest water 78 degrees C
Introduced thermostatically controlled taps in Kitchen and Bathroom for shower. (Had to it was too hot) Takes 15 minutes sunshine to reheat water when run cold. Have showers off it and don't need to rush :) Fill washing machine up with solar heated water so saving there also. Used to have leccy shower, now have solar shower saving more leccy.
Black plastic tube coil acts as expansion tank and also primary heater for the water, plus extra reservoir. May change to larger bore tubing but it works so don't fix it for now at least.
Thanks for the comment Dave.
Andrew
It has a diy heliostat thread and also a diy cnc thread.
Come join us!
Great instructible - and keep us updated with the heliostat!!!
