3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solar powered electric car
After converting 1995 Aspire to electric vehicle ,I decided to go 1 step further. I installed 6 solar panels on garage roof , with batteries and inverter in garage. Car charges during the day and I drive it on after work missions. Works great driving around town (usually only 5-10 mile trips) will go 55 mph. If it is cloudy a few hours charging continues due to batteries in garage.
Step 1Remove engine
Remove engine
First step is removal of engine and components, radiator , tailpipe , muffler ,etc
85 comments
1-40 of 85next »
Mar 5, 2012. 11:30 AMclintcooper2003 says:
How many total miles can you go off of one charge?
May 16, 2012. 8:23 PMsolar car says:
50... i think.... i would think...idk
Aug 29, 2011. 9:40 PMDRC888 says:
You could try putting vents at the top of the bonnet (Windsheild end) to help the air flow freely through and reduce drag.
I don't know if it will work but could be worth trying :)
Apr 13, 2009. 2:40 PMPlanecrazy361 says:
Where in IL are you? I'm in Buffalo Grove, and would love to see the car someday if you're not too far away! Regards, Steve
Aug 11, 2011. 8:48 PMspeedy4442001 says:
Yes, I too am in IL and wondering how far away from you I am. Also wondering if you do conversions for other, mechanically challenged people? And you total costs? I am very impressed!! Good job!
Apr 12, 2009. 7:14 AMmisterwelder says:
Awesome job. I've been wanting to go electric with and old beetle for a while now. I hope to have the success that you have.
Nov 15, 2010. 11:55 PMBGreenHVAC says:
Why ruin a valuable car like an older VW. If it is old enough to not require a seat belt, It is an extremely valuable VW. It would make more sense to restore the Beetle and sell it. There should be enough cash to buy a new electric car if you wanted.
Oct 4, 2010. 4:57 PMDr. Al says:
It seems Tesla is also taking this convert a gas car (Lotus) to electric and add solar panels to the garage roof. The better solution is found at Stinger Motors Inc.
Mar 11, 2010. 11:01 AMThreeWestCreative says:
Your Car is awesome and gives us great hope for having our own electric cars and the video I posted shows this guy with an electric car beating high class sports cars and using smaller batteries. :)
Mar 11, 2010. 10:59 AMThreeWestCreative says:
Jan 16, 2010. 12:32 AMdesotojohn says:
Have you thought about mounting the solar panels on top of the car?
Dec 21, 2009. 12:23 PMpmartinez says:
Great project.!
I though about making a conversion myself, however; I live in Costa Rica and hill are steep here, I assume battery life would not last the typical 40-60 miles. I have a question:  Sorry if it sound "dumb", can a small generator be attached to the car, in order to "boost" the energy going up hill, and charge batteries on a long trip. I understand it defeats the purpose of going "electric", however; is a though for "emergency" boost.
Thank you
Jul 7, 2009. 6:49 AMtristantech says:
Is something like this street legal? or did you have to get this approved with the government before you could drive it on the street?
Apr 12, 2009. 8:17 AMrommel543 says:
What kind of speed and distance do you get out of the car? I was looking into a conversion kit but it only went 60-75 miles per charge and took 8 hours to charge the batteries.
Jun 22, 2009. 6:44 PMluigi2999 says:
If ur car ran on 48V, you could use a couple of 48V LiFePo batteries, which have a vary high energy to weight ratio.
Apr 12, 2009. 8:18 PMguitarman63mm says:
How does lower temperature slow you down? I thought electricity conducts better at low temperatures. Or perhaps you're talking about something else...
Apr 13, 2009. 5:13 AMJerryMopar says:
you are correct with the temperature situation about the circuits, but batteries like the temp just right, not too hot, not too cold
May 27, 2009. 8:46 AMbernarte_affiliate says:
how many voltage is the electric motor?
May 18, 2009. 11:32 AMrankhornjp says:
You can check out http://www.diyelectriccar.com for all kind of information about conversions.
Apr 30, 2009. 10:47 PMSkitter302 says:
I like the plan, food for thought here>> how about mounting a fan for a generator about were a trailer hitch would go( just under the rear bumper).
Apr 19, 2009. 10:10 AMsebberdreng says:
You allready have a mac you maket the on it i can see.
Apr 16, 2009. 9:26 AMmuell291 says:
Nice to see your combat robot skills going to good use here! What are the amp-hour ratings on your batteries on both the car and the home station?
Apr 17, 2009. 10:00 AMblksheep says:
What kind of motor did you use? It looks so dinky compared to the engine you removed. Could you give the specs on it? I'd like to know where I can get one.
Apr 14, 2009. 2:47 PMsrharvey says:
There has to a be a better way to charge the car off the solar battery pack. Converting from DC to 120V AC and then back to the DC in the car seems like a waste.
Apr 15, 2009. 9:31 PMAdHd says:
Plus, your setup allows you to recharge the car anywhere you go, not just at home. If you had enough batteries at home, you could also drive the car to work and charge it overnight from the solar batteries. Your setup gives you lots of flexibility at the cost of some efficiency - I wouldn't change a thing.
Apr 13, 2009. 12:34 PMFunk_D says:
What if you had a gearing system that activated whenever you pressed the brakes that kicked in alternators and regenerated energy while providing a little bit of stopping power? (in union with the regular brakes of course).
Apr 14, 2009. 6:10 PMFunk_D says:
Actually, the more I thought about it, wouldn't the motor work in reverse as a generator whenever you weren't applying current to it and the car was still moving (such as downhill travel and braking) while providing resistance?
Apr 15, 2009. 9:25 PMAdHd says:
It's called regenerative braking http://en.wikipedia.org/wiki/Regenerative_braking Check it out. Every hybrid uses this technique, as do electric trains. I think you'd need a speed controller which includes that feature, but I'm no expert.
Apr 12, 2009. 3:12 PMdjr6789 says:
one other thing you could do is instsall some sort of windturbine behind the radiator's grill to charge up the batteries while driving
Apr 12, 2009. 4:34 PMNoodle93 says:
But. Wouldn't that cause more drag? Or else you'd be talking about a perpetual motion machine. Which is impossible. Well I think that's what you're talking about.
Apr 12, 2009. 5:13 PMdjr6789 says:
im not sure about what your talking about. i just meant a little wind turbine behind the grill so it uses up the air that passes through the engine bay and turns it into energy. P.S sorry if the first sentance sounds mean DJ
Apr 12, 2009. 11:25 PMsax-matt says:
Noodle is correct. You would end up having to use more energy to get the little wind turbine to move than you would gain. I saw an 'ible a while back talking about installing a turbine to an air conditioner fan and had a similar discussion about this. Good thought though!
Apr 13, 2009. 12:16 PMBorisTheSpider says:
I don't know. If you set it in s place where there's already drag (like a flat angle), that's energy that would hve been totally wasted on drag but instead gets converted back into electrical energy.
In other words, you're still not going to make up for the energy wasted on drag, but you'll make up a little bit that would have been wasted.
1-40 of 85next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:mrmusty
