Solar powered nocturnal personal fan
A small fan, driven by a hobby motor. Powered by 2x AA rechargeable batteries. The batteries are hooked up to a solar panel, which recharges them during the day.
The circuit is switched by a CdS cell (light switch) which means the fan switches on when it is dark enough, at night, hopefully.
Only after I'd built the (incredibly ugly - sorry, no photos available) prototype did I realise I could've bought a pesonal fan for $5 and hacked it instead.
Here's the schematic. Feel free to use it or improve upon it to your own satisfaction.
Step 1Parts, clarification, that is.
The transistor is an ordinary NPN 100mA 45V.
The CdS I hacked from a solar garden light.
The solar panel came from the same place.
It's output is (rough estimate) 4.5V, 60mA.
I used an old hobby motor with a range of 2-6 volts. No special reason, it was handy. And the propellor came from a model plane.
That leaves the diode, 1N4004, and the two resistors, 1k and 10k.
9 comments
Jul 27, 2011. 4:49 PMgaby1st says:
Hi there,
I have a question here what is the meaning of LDR.Thanks u.
Apr 9, 2011. 8:19 PMaccount3r2 says:
Could you swap the light sensor with a switch?
May 12, 2009. 6:24 AMTheYetti says:
I don't really understand are these just the Blueprints for the fan..?
Apr 28, 2009. 2:23 AMLosenger says:
What's the purpose of the 1K resistor? It will work just fine without it. Change the 10K fixed resistor to a potentiometer to be able to adjust the point at which the transistor turns on. Swap the positions of the 10K and photo-resistor to create a "light on" switch. Also, the diode doesn't have to be a 1N4004. Any 1N400x series diode will suffice.
May 10, 2009. 12:18 PMn0ukf says:
Or if you give it a thermistor, you can have a temperature controlled fan.
Aug 24, 2008. 12:05 AMYerboogieman says:
whats the input into the fan; voltage?
May 10, 2009. 12:14 PMn0ukf says:
To the motor? Two NiCd cells @ 1.2V each, 2.4V.
Jan 24, 2009. 3:30 PMrevhead says:
I used a similar circuit in my rechargeable battery powered laser for an alarm system.
you can check my Instructable out to see how you can even further enhance this circuit at:
http://www.instructables.com/id/Laser_Beam_Alarm_System_with_Rechargeable_Battery_/
Apr 12, 2008. 3:15 PMawkrin says:
I guess no one will do this thing on a pcb, but just in case, here's a pic generated from croc tech 3d I edited it a little to make it more clear...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Wonko the sane
