Solar rainbow discoball!
This instructable shows you how to make a solar powered rainbow disco ball! A tiny solar panel powers a motor that turns a few cut glass crystals in the sun. These project moving rainbows around your room!
We use what is called a solar engine to make this work. A solar engine is like a bucket that slowly collects the photons from the sun until the bucket is full. Then we empty the bucket all at once into the motor which turns a tiny bit. Even then, the motor isn't powered enough to move the crystals much, so we also need a gearbox.
If you want to know more about how solar engines work, read up on the BEAM website.
This instructable makes use of a PCB to make the construction easier, sturdier and better looking.
You can buy a PCB from me at cost price (£1.50)
You can also use a veroboard, or you can solder it all together with no board. In which case, have a look at the attached circuit diagram.
You'll need some basic soldering skills to complete this project, so if you're unsure then check this instructable.
Step 1Components and tools
Components:
* solar panel (this turns the photons from the sun into electrons),
* C1: 2000uF or greater capacitor (this is the bucket that collects the electrons),
motor and gearbox (this is what we power with our bucket of electrons),
* T2: 2n3906 PNP transistor (this is part of the switch that empties the bucket),
* T1: 2n3904 NPN transistor (this is another part of the switch),
* R1: 2k resistor (this is another part of the switch),
* D1 and D2: 1n4001 diodes (this is the bit that detects when the bucket is full enough),
* veroboard, a PCB, or just solder it all together in situ.
* cut lead glass crystal(s) at least 20mm wide for big rainbows!
* window sucker,
* thin cable tie to attach the motor,
* connector block to attach the crystals to the gearbox shaft.
* some thread, or fishing line to attach the crystal(s).
Tools:
* glue,
* soldering iron, solder,
* wire cutters,
* small flat head screwdriver,
* maybe a sharp knife,
* maybe a file.
The total cost of components comes to £9.51 if buying in quantity. If you want a complete kit, please email me.
7 comments
Nov 16, 2010. 4:43 AMzcrank says:
Nice Solar Engine project all ready in gift form! Been looking for this exact DIY Write up!
Feb 13, 2010. 12:01 PMrimar2000 says:
When you say "... I have noticed that not all light sources will make it work. I found with this panel, a 25W halogen worked, but a 12W compact florescent didn't...." It is true: a diffuse (not punctual) light as the fuorescent tube does not make the diffraction of light as it takes to make colors vivid. The surface of the tube is very larger than that of the halogen lamp filament.
Feb 13, 2010. 12:46 AMfrollard says:
Neat project!  It's a shame the pcb had the error - I learned a lot about prototyping with my own homemade circuits - there's always a bug before you send it for fabrication!
Any chance you'll publish the board files?
Feb 13, 2010. 4:23 AMfrollard says:
Wonderful!  Really is a part of the whole sharing process :D
Feb 13, 2010. 4:26 AMfrollard says:
**also, linking to schematics on another site is okay - but if ever that site goes down then this instructable is practically worthless.  Best to include all files/instructions embedded here for data integrity.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:matthewvenn
I'm an artist/engineer excited about making cool stuff!
