We use what is called a solar engine to make this work. A solar engine is like a bucket that slowly collects the photons from the sun until the bucket is full. Then we empty the bucket all at once into the motor which turns a tiny bit. Even then, the motor isn't powered enough to move the crystals much, so we also need a gearbox.
If you want to know more about how solar engines work, read up on the BEAM website.
This instructable makes use of a PCB to make the construction easier, sturdier and better looking.
You can buy a PCB from me at cost price (£1.50)
You can also use a veroboard, or you can solder it all together with no board. In which case, have a look at the attached circuit diagram.
You'll need some basic soldering skills to complete this project, so if you're unsure then check this instructable.
Remove these ads by
Signing UpStep 1Components and tools
* motor and gearbox (this is what we power with our bucket of electrons),
* veroboard, a PCB, or just solder it all together in situ.
* thin cable tie to attach the motor,
* connector block to attach the crystals to the gearbox shaft.
* some thread, or fishing line to attach the crystal(s).
Tools:
* soldering iron, solder,
* wire cutters,
* small flat head screwdriver,
* maybe a sharp knife,
* maybe a file.
Any chance you'll publish the board files?
