3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solar water heater from pond liner
Guess you know that there is nothing greater than a fresh bath in the heat of the summer. But with the end of summer the high temperatures will be gone too and going for a bath outside might be just a bit chilly. But not with a solar heating device for your pool, that will heat your pool for free!
There are a few high price solutions to this problem, but nothing really useful or portable. This device I present here can be carried around (if empty!) and used anywhere where you want to have warm water. It is quite stable and cheap.
Step 1Parts
Parts
You need:
- 2m x 2m of 0.5mm black PVC pond liner. 0.5mm is enough and of course it should be black! That should cost you something around 8-12Euro.
- 150-200ml of PVC-Glue. Most people think that PVC is not glueable, but that is not really true. You can actually buy this kind of glue I think it consists of soluted PVC in butanol. In Germany it is sold in cans of 200ml and 1000ml by 'Heissner' for example. But ebay should give you a lot of alternative sources. This stuff is either for pond construction or repair of inflatable boats. This might cost you something around 10.-Euro for the small can up to 30.-Euro for the liter.
- 30cm of PVC-tubing 12-20mm diameter with suitable adapters to your favorite hose-coupling
- a cheap paint-brush, because it will be destroyed after use. Some PVC-glues come with brushes in the cap of the can. Watch out for these!
- a few old rags
- 250ml of benzine, for cleaning purposes
- a flat space of 2x1m somewhere outdoor in the shade
5 comments
Jun 17, 2011. 11:20 AMJeonLab says:
This is great idea! I also agree with rimar2000's comment that any transparent plastic cover will increase the temperature.
Thanks for sharing!
Dec 20, 2009. 11:29 PMl8nite says:
  This is a really neat idea, well thought out and executed.
Ive mentioned this on here before but I think its worth repeating. When I was little (in the 1960's before green was anything but a color) we had a couple of truck innertubes, these were laid flat on the van roof or top of the boats cabin, there was a hose coupling on the top with a cap and a short length of hose on the lower side with a valve. The water got really hot during the day. It wasn;t for drinking of course but for washing up and gravity showers
Nov 25, 2009. 2:01 PMamackie says:
In my opinion something like this, placed on a flat surface and filled with water, would not blow around in anything near an average thunderstorm. It's just to heavy and to low for wind to get under and lift.
Sep 2, 2009. 5:33 AMmr.incredible says:
Awesome idea. I've been looking for a cheap way of extending the swimming season. I imagine a shorter version could also be used for a camp shower. Maybe one about 4x8 laid out flat. I wouldn't want to backpack with it but a camp site location with only cold running water would benefit. Or even a much smaller version hung up with an open end and a shower head and valve would last longer than the store bought camp shower
Sep 2, 2009. 4:46 AMrimar2000 says:
Very good work. I suppose that if you cover the mattress with a loose clear polyethylene sheet, it will protect the heater from the wind and thus it will be hotter.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
50
Author:andyk75
I like to explorer new things and try out stuff. At the moment I'm in to electronics and LEDs (mainly).
