Solder Fume Extractor | Super Easy to Make
3,251
72
8
Posted in TechnologyElectronics
Introduction: Solder Fume Extractor | Super Easy to Make
Let's Do This! (High Five and Freeze Frame)
Thank you for checking out my project! I have more on my YouTube Channel youtube.com/c/3dsage
Why use a fume extractor? "Exposure to rosin can cause eye, throat and lung irritation, nose bleeds and headaches. Repeated exposure can cause respiratory and skin sensitization, causing and aggravating asthma. Rosin is a serious occupational health hazard."
What can you do? Make this simple fume extractor! Just two main pieces and easy to assemble. The carbon will help filter the hazardous fumes. Other extractors online are expensive and some use batteries but I think this is better since it uses a wall outlet.
I am such a visual learner that I made this video that shows you all the steps so you don't have to view the steps below if you dont want to. Either way I hope you enjoy this simple project.
Follow directions correctly and always be smart and be safe.
Step 1: Materials
Titan 80mm Dual Way USB fan
Imagitarium Carbon Filter 10"x18"
Something thin and pointy like tweezers
A USB to wall outlet
USB extender (optional)
Carbon filter at Petco: https://www.petco.com/shop/en/petcostore/product/i...
Fan at Frys electronics: https://www.frys.com/product/7962220?source=google...
Step 2: Assemble Fan
The fan will come with 4 thin rubber pieces that will hold the fan together. Pull the 4 pieces all the way through starting with a black foam, then white foam with the fan inside, then black foam. The bluish Titan logo will face forward.
Step 3: Foam Base
The fan also comes with two circular foam pieces that you can slide on the base of the fan.
Step 4: Carbon Filter
Grab the carbon filter and cut a square 9cm x 9cm. The carbon kind of gets messy so put a paper towel underneath to catch any small pieces.
Keep the rest in case you need extra filters.
Step 5: Attach Carbon Filter
Use something thin and pointy to poke 4 holes into each corner of the carbon filter. The holes need to be thin enough so the rubber pieces will pass through and catch to hold it to the fan. The same way as the 4 rubber pieces are holding the 3 foam pieces of the fan.
Step 6: DONE!
With the carbon filter securely on the back of the fan, the smoke from the solder will be drawn into the fan and filter.
I hope you enjoyed this and if you did, feel free to check out my YouTube channel 3DSage for more fun projects!
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
    • Casting Contest
      Casting Contest
    8 Comments
    Nice job, it is a welcomed addition to any work bench. I bought one years back, but the AC fan motor is quite loud. It may be time to swap out the motor for a DC fan.
    Thanks for sharing,
    Build it Bob
    Yes I am impressed with how quiet this fan is. It is a good addition to have. I am glad you liked this so thank you for the comment!
    Thank you! It is designed that way and it works great for me.
    Thank you for saying that. I'm glad you like it.
    Thank you! Yes I think it does and it's quiet, strong suction, good filtering, no batteries to deal with, and easy to make.
