Solder Headers to Wire...Without the Hassle!
18,357
12
18
Posted
Introduction: Solder Headers to Wire...Without the Hassle!
Impress your wife by saying your going into jewelry. (Not really.)
It's more like a compromise.
If you're like me (and I think you are) you find that soldering wires to male headers is very annoying. First of all, if you leave the tip on the header for too long, it will melt the plastic holding it bringing it out of alignment.So, John Fattaruso developed this interesting way of soldering to leads. I personally find it extremely useful and very helpful.
Why would you need to solder to headers? Well, if you didn't solder to headers, then if you plugged a wire into the Arduino, Propeller, or even Basic Stamp, it would easily fall out.
Step 1: Find Your Materials.
You will need:
Crimp Beads AKA Crimp Tubes (You can buy them here) (They come in four sizes. Sizes One and Two work best for our project.)
Male headers
Wire.
A board to test your finished project (Breadboard, Arduino, Propeller, etc.)
Step 2: Build It! Part 1
Start by placing the bead on the header.
Then, insert a wire between the bead and the pin.
Step 3: Build It! Part 2 - Squeezing and Soldering
Next, you take a good pair of pliers and then squeeze until the wire is fairly secure.
Finally solder.
Step 4: Done!
Now, you know how to solder to headers with some jewelry.
Your wife should be proud. (I think.)
As always...if you experience any problems leave a comment and I will try my best to help you.
If you did make it successfully well then...leave a comment saying you made it successfully!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
18 Comments
I disapprove. That jewelry you used in the pictures is really ugly.
When the pin is of square section, as in this case, it is very easy to wrap the wire around it. Then you can solder it, if you want.
The trick is to pull the metal pins out of the plastic carrier, solder them, then push them back into the plastic. Takes a macho man with some muscle to do it though :)
But seriously if you grab those pins with some needle nosed pliers you can pull them right out. I tin wire and pin, then just lay the wire right up onto the pin and solder it.
The REAL trick is soldering a wide ribbon cable to header pins. Then it helps to be good soldering. Because you can't pull the pins out and have things come out evenly.
The one in the picture is a narrow one, I've done up to 25 wide. When you get that wide you have to cut the cable concave because the outer wires need to be longer to make it to the pins.
use a 6$ wirewrap tool, ribbon fits fine in them and once you get all the wires wrapped touch with solder, no skill required
Nothing proper diet and exercise can't fix I'm sure.
Being physically fit never hurt anyone.
True. but, jewelry has its advantages.
Pre tinning the wire and the header is a big help. You can then press them together, apply brief heat, and you get a pretty good joint without anyting else. ( wire and header should be parallel to maximize contact ) Coating the whole thing with hot glue or something similar will make the connection mechanically stronger and stop it from bending ( and breaking ) right at the joint.
