Introduction: Solder-less Solar Panel
Picture of Solder-less Solar Panel
Various voltages depending on how you string these together, series, parallel or both
Simple, no soldering
Items needed:
1) Broken Photo-voltaic chips: available via Google search, hobby suppliers
2) Aluminum foil
4) Acrylic covered blank page from a photo album
4) Duct tape
5) Two small pieces of wire
6) Volt Meter for testing output
The secret is in the duct tape. Tape top side first. Pull down hard on clear plastic while using duct tape to secure bottom, right and left sides. The pressure connects the foil to top and bottom (positive and negative) sides of PV chips
Will drive small motors and fans to teach DC voltage to yourself or children
Not for outdoors (long term). Moisture and condensation will effect conductivity.
Step 1: Items Needed - Simple
Picture of Items Needed - Simple
Requirements:
Rudimentary knowledge of basic electricity concepts and DC voltage
Ability to use a voltmeter to test output of DC voltages and amperages
Scissors
Step 2: Solder-less Solar Panel
Another example - positive side = right, negative side = left
dasimpson1981 (author)2015-01-25
if you use the conductive glue like i said you can just over lap the panels
GregRank (author)dasimpson19812015-01-26
Thanks for the tips!
also use a glass cutter to try and make them as much as possible the same size
use finer stips so you dont cover as much of the surface also mic some graphit filings from a pencil to supler glue to make conductive glue
About This Instructable
772views
15favorites
License:
Bio: Dinosaur Rex's lived in Texas. And that's a great big place In the United States. Still they both seem small, 'cause if I ... More »
More by GregRank:Grandpa's DreamChromebox Sound FocuserThe "GO" House - micro living with 54 square feet
Add instructable to:
