Step 7Making the Connector
-Straighten out the paper clip (it doesn't have to be perfect, it just helps with the shaping) (or use the left-over bits)
-Grip the very end of the paper clip with the pliers
-Using the rest of the paper clip for leverage, bend the paper clip around the end of the pliers as tight as you can; until it is parallel with the end in the pliers
-Reposition the pliers about 1 to 1 1/2 cm farther on the paper clip
-Using the rest of the paper clip for leverage, bend the paper clip around the end of the pliers as tight as you can; until it is parallel with the part in the pliers
-Cut off the excess paper clip, leaving a tiny gap between the two ends
Connecting the connector
-Bend the ends of the connector apart (so that the gap is big enough to fit that last links of the bracelet though it)
-Slip the last link (from one of the ends)though the gap and into the connector
-Warp bracelet around your special someone's wrist
-Slip the last link (from the other end)though the gap into the connector
-Bend the ends of the connector closed
Add Comment
