Never soldered before? Here's where to start.
If you appreciate this instructible, please visit my blog for more ideas:
GoodCleanCrazy
Last week I decided to make a USB powered flashlight.
While I know a lot about computers, I'm pretty much a solder newbie.
This was a problem.
Luckily, though, I work with a formerly-NASA-micro-soldering-certified technician and soldering instructor.
Yesterday, he instructed me as I soldered together my lovely little flashlight.
My newbie perspective is useful as I won't overlook any "obvious" things that more experienced solderers might.
And my knowledgable overseer (Thanks Terry!) taught me the proper methods, so you can do things the right way too.
You will need:
water
solder
A soldering iron
If you can't get a soldering iron with a digital temp readout (and I can't) get a soldering iron with a temperature dial. You'll be glad you did in the long run.
Remove these ads by
Signing UpStep 1Prepare the Iron
**If you're reading this instructable, you shouldn't be soldering chips (ICs) yet, but if you WERE to solder ICs, you'd be soldering on an ESD mat.
Plug in the iron and turn it on. Using water, soak the sponge that comes with the iron and squeeze it out a little. This sponge is used to clean solder off the tip of the soldering iron.
Adjust the temperature of the iron to about 750 F(75 on the dial) like so:
I just bought a iron from radioshack, and it cost about $8. I got home turned it on and suposedly tinned it( melted the solder on there and wiped off the excess. My joints were not perfect, but as I went on I relized my tip was eroding away. What can I do to stop this, I have rosin core solder. This has happened to me plenty of times before. Is it me or the fact that I have a cheap soldering iron? Please help. A video would be realy nice.
now I have not been using it all that much, but my good iron came with a flux soaked brass sponge and its tip is just now starting to show some wear over 2 years later.
The other side of that coin is people argue the metal sponges scrape off the coatings used on better quality tips, though I have never seen brass foil knock a hole in to cast iron ...
have fun.
To add to the above, I believe one of the many good reasons to buy a temperature controlled soldering iron is that you can adjust the iron temperature for both the job at hand (heating more metal takes more energy, too much energy damages fine components) and for the specific mix of solder you are using. There are many off brand digital thermocouple controlled adjustable irons available nowadays, and little research should turn up several between $50-$100US. They provide a drastically different experience than the standard $10US blister pack iron. My advice is that if you intend to work on circuit boards of any kind (as opposed to just the occasional wire tinning or appliance mending) you will be well served by investing in a good iron.
More details can be found on the soldering iron and solder pages on Wikipedia, and out in Googlespace. Some brand names to search for would be Weller, Hakko, Aoyue, and Xytronic.
The advice is good--steel wool can help if components are heavily corroded--but soldering without any flux is almost impossible. Luckily most solder comes with flux built into its core, but this flux will burn off quickly if you put solder on the iron tip and let it sit there (fumes are actually from boiling flux, not lead). The main job of flux is to remove oxidation from the metal and keep air away until solder displaces it. The key is having an un-corroded surface, not necessarily a rough one.
The video at the top of this page has some shots showing soldering with and without flux: http://www.curiousinventor.com/guides/How_To_Solder
