Step 4Why Tin?
Try to solder immediately after tinning the tip, the sooner the better.
Periodically while you are working (after soldering one or two connections), clean and re-tin the tip.
Tinning improves conductivity and makes soldering easier, as well as quicker, which is a good thing.
Some electronic components are sensitive to heat, and the quicker you can solder them, the less likely they are to be heat damaged.
According to the instructive Terry, properly tinning the iron tip before putting it away will help preserve it.
Comparing our soldering iron (like new), and the iron of the guys down the hall (terrible) this seems to be a good practice to keep.
Happy soldering! -Royal
Like this instructable?
Try Soldering 102: Soldering a Jumper Next!
I just bought a iron from radioshack, and it cost about $8. I got home turned it on and suposedly tinned it( melted the solder on there and wiped off the excess. My joints were not perfect, but as I went on I relized my tip was eroding away. What can I do to stop this, I have rosin core solder. This has happened to me plenty of times before. Is it me or the fact that I have a cheap soldering iron? Please help. A video would be realy nice.
now I have not been using it all that much, but my good iron came with a flux soaked brass sponge and its tip is just now starting to show some wear over 2 years later.
The other side of that coin is people argue the metal sponges scrape off the coatings used on better quality tips, though I have never seen brass foil knock a hole in to cast iron ...
have fun.
To add to the above, I believe one of the many good reasons to buy a temperature controlled soldering iron is that you can adjust the iron temperature for both the job at hand (heating more metal takes more energy, too much energy damages fine components) and for the specific mix of solder you are using. There are many off brand digital thermocouple controlled adjustable irons available nowadays, and little research should turn up several between $50-$100US. They provide a drastically different experience than the standard $10US blister pack iron. My advice is that if you intend to work on circuit boards of any kind (as opposed to just the occasional wire tinning or appliance mending) you will be well served by investing in a good iron.
More details can be found on the soldering iron and solder pages on Wikipedia, and out in Googlespace. Some brand names to search for would be Weller, Hakko, Aoyue, and Xytronic.
