Soldering 102: Soldering a jumper
This is my second basic soldering guide from the beginner, for the beginner.
It covers soldering and unsoldering the most basic component, a jumper wire.
Never soldered before? Start with Soldering 101: Tin the Tip.
If you appreciate this instructible, please visit my blog for more ideas:
GoodCleanCrazy
You will need:
All the items used in Soldering 101
flux paste
insulated jumper wire
pc prototyping board, veroboard (stripboard), or padboard.
wire strippers
dikes (diagonal cutters) or flush cutters.
solder sucker (desoldering pump)
**The links above are simply the place I found these items. Any suggestions for other US links would be appreciated**
Step 1Strip the wire
Strip the wire
Open the strippers. Poke about half an inch of wire in a cutting groove slightly smaller than the wire diameter. Clamp the stripper closed and rotate it about a bit. Then flip the stripper over and pull the wire through.
34 comments
Jun 14, 2010. 1:49 PMUser1 says:
Thanks for putting this instructable together. Being an absolute noob, I found it VERY helpful. I read all the instructions on my new Weller soldering station and gun, and I was WTF? I don't ANY of these terms they were talking about. Now I see what I gotta do and still buy, and more important, why. Thanks again!
Apr 11, 2009. 4:14 PMjpoyner says:
I don't think you ever touched on what the flux does for the work. Why do we need it? Is it absolutely necessary or just part of Terry's strict guidelines?
Dec 3, 2009. 5:15 PMColonel88 says:
Flux strengthens the connection between metal & surface, so if you are soldering to like a penny, put some solder on. In America, there a a bit of flux in the solder, hence "rosin core". Rosin is most commonly used in Flux. In other countrires however, they use separate flux, not the one inside of the solder. For exmple, Russia.
Sep 26, 2009. 7:53 AMBFeely says:
Clipping the wire after soldering can cause the solder to crack or have internal stresses, which could weaken the solder joint.
Dec 3, 2009. 5:12 PMColonel88 says:
Yeah, that's why when I solder, I don't cut it too much to the point.
Sep 26, 2009. 7:51 AMBFeely says:
Lead free solder may have a dull finish. It should still have all the other qualities of a good solder joint.
Aug 14, 2009. 7:40 AMmetalmarious says:
also you can nails(if the wire isnt too thick)
May 20, 2008. 3:48 AMcollard41 says:
if you use flux solder you wont need to use flux. also it is not necessary to tin the tip every time you solder. soldering is easy and should not need an Instructable to show you how to do it
Aug 27, 2007. 8:40 AMpjax says:
how do you put flux on something you can't dip in flux? like legs of ICs? and do you tin them as well?
Jan 24, 2008. 9:42 PMcornholio says:
Generally for soldering smd's and surface mount chips, or other things you cant dip in flux you would just use a q-tip and dip that in the flux, then wipe the flux on your solder point
Nov 6, 2007. 7:49 PMacid-burn says:
nice instructable i like it.
Oct 24, 2007. 8:59 AMjimepler says:
very helpful pictures and instructions for this step of the process.
Apr 16, 2007. 1:42 PMPopular Mechanics says:
Here is a video on how to solder to a circuit board. Mike is quick about it, but you get a good idea of the technique. The video and accompanying text article can be found here.
<embed src="http://services.brightcove.com/services/viewer/federated_f8/271552687" bgcolor="#FFFFFF" flashVars="videoId=626875109&playerId=271552687&viewerSecureGatewayURL=https://console.brightcove.com/services/amfgateway&servicesURL=http://services.brightcove.com/services&cdnURL=http://admin.brightcove.com&domain=embed&autoStart=false&" base="http://admin.brightcove.com" name="flashObj" width="486" height="412" seamlesstabbing="false" type="application/x-shockwave-flash" swLiveConnect="true" pluginspage="http://www.macromedia.com/shockwave/download/index.cgi?P1_Prod_Version=ShockwaveFlash"></embed>
Apr 18, 2007. 7:23 PM25Kilovolt says:
teeth work pretty well for that to
Mar 2, 2007. 2:24 PMN5VTD says:
Solder moves to the hottest point.
Jan 24, 2007. 8:24 PMNessTheHero says:
What is flux and why is it necessary.
Jan 25, 2007. 5:37 PMpfred1 says:
Flux for electronics is supposed to be rosin based. Acid fluxes are mainly for non electrical mechanical connections. Even though rosin flux contains abietic acid as its cleaning agent, it is not considered an acid flux, like zinc chloride, or ammonium chloride based fluxes. The main purpose of fluxes is to shield the base metals from the atmosphere as the metals are heated up to avoid oxidization that would normally occur at the elevated temperatures soldering takes place at.
Jan 30, 2007. 9:11 PMjulianj says:
great explanation. thank you.
Jan 25, 2007. 11:10 AMNessTheHero says:
Yes, thank you. It just confused me because I had never seen that used in any of the other soldering tutorials on instructables and you didn't explain what it was in your steps.
Jan 17, 2007. 9:10 PMMr.Devious says:
Thanks for the instructable. It's good to see that some people are willing to teach us the proper ways of things. Good for newbs.
Jan 19, 2007. 12:01 PMMr.Devious says:
Now can you tell me what I'm doing wrong, when I try to solder anything, I find that the solder sticks to the tip and I can't apply the solder without putting enough on the tip to make it drip, but that's pretty inacurrate and you could end up with solder splashes. I know that you're not supposed to put the solder directly on the tip, but rather onto what you're working on, I'm guessing it's just because it's a cheapy soldering iron. I think it's a $35 one from crappy tire.
Jan 19, 2007. 5:48 PMMr.Devious says:
Well I don't have a sponge handy, but yes the solder I use is fairly heavy gauge and has rosin flux, it get's pretty smoke :-P. The tip is usually tinned. Could it be that I'm using such a heavy gauge of solder?
Jan 25, 2007. 6:14 PMpfred1 says:
When you solder, don't feed the solder to the tip, use the tip to apply heat to the joint, then feed solder to the joint.
Jul 19, 2007. 3:14 AMJames (pseudo-geek) says:
yes def use thinner solder. I use the second-to-smallest gauge that radioshack sells and it works great.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
26
Author:royalestel(GoodCleanCrazy)
Every now and then I come up with a unique idea. And then I find someone else has already thought of it . . . which is AWESOME! Who knew there were so many kindred spirits on the web! YOU GO all o...
more »
