Step 3Solder the jumper to the board.
Clean and tin the iron tip.
Again, hold the iron on the opposite side of the wire as the solder. Briefly touch both iron and solder to the base of the wire.
A good solder joint is shiny. If yours is foggy or dull-looking, you've got what's called a cold solder joint. This is bad. It's weak and has poor electrical connectivity. Either your iron wasn't hot enough, or you need to clean the tip, or you took too long to solder that sucker. Try melting down the existing solder again.
The solder joint should also not have too much solder. A little volcano-shaped hill all around the base of your wire is a nice "fillet" joint. A bulging, rounded hill is bad, as is a spot around the base with no solder.
comment
Add Comment
Add Comment
