Soldering Helping Hands From Junk
Introduction: Soldering Helping Hands From Junk
Do you want to make a nice pair of soldering helping hands from JUNK?
Step 1: What You Need
You will need a base. I used a piece of steel from a broken computer monitor because it has two pre drilled screw holes. You can also use a wooden base. You also need two short sections of solid copper wire. You also need two small binder clips.
Step 2: Prepare Your Wire
Strip a short section on one end of the copper wire. Bend it into a loop. Repeat for the other section of wire. Use this loop to screw your wire to the base.
Step 3: Clips
Pass the wire through both ends of your binder clip, then bend the wire around to secure the clip.
Step 4: Use It
Be careful not to bend the wire too much or else you may snap it.
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
