Introduction: Soldering Iron Control Temp
Picture of Soldering Iron Control Temp
Published on Jul 28, 2014
This project will help you controlling the temp of your soldering iron. As well an indication while in on status The advantages of this project, clean solder joint, minimize tip wear.
you can watch the movie in bellow link:
for up-to-date contents, you can follow me and subscribe in my channels:
http://www.youtube.com/user/Abu7li1
https://www.facebook.com/Abu7li1
https://www.instructables.com/member/abu7li/
PinakiG (author)2015-09-09
Sir, can I use DIAC DB3 instead of BR100 and TRIAC BT136/600D instead of BT131?
Can I use my 65W/240V AC iron?
I will be building the circuit on veroboard. Please mention the live and neutral channel in your circuit. Also I'm planning to use a wire direct from the iron body to earth to prevent shock from leakage current.
syedhamzahasan (author)2014-09-26
what do we calibrate? Please explain that part.
Thankx
Hi syedhamzahasan,
if you trace back the schematic, you would find that the pot 470k is used to fire the TRIAC bt131. and since you are going to rotate the pot left&right for desired temp. u may want to calibrate (write done on the soldering iron) the actual temp for every position. hope this helps.
Regards,
Abu7li
Applied Electronics (author)2014-07-28
http://www.youtube.com/watch?v=s8Qzz9Y-Fxc&list=PL-DYRTx2yMmnM4w-YxNGwRg30SBGrpSpF&index=1
About This Instructable
1,030views
9favorites
License:
Bio: Follow me on: YouTube / Instagram / Facebook / Applied Electronics
More by Applied Electronics:Battery Bank Recycled From Laptop BatteryBeating HeartDesk Light
Add instructable to:
