Introduction: Soldering Iron Stand
A few years back my grandfather gave me a gift of his old soldering iron. I've gotten a lot of use out of it and decided that it's finally time to build my own stand for it!
Step 1: Preparing the Form
Picture of Preparing the Form
We're going to be using a coat hanger for the coil that the iron sits in. To make this coil, I drilled a hole the same width as my coat hanger in an old broom.
Step 2: Making the Coil
Picture of Making the Coil
I cut the coat hanger down and inserted it into the hole I had just drilled. Once it was secured, I began to wrap it around the broom handle, producing the coil that we need.
Step 3: Safety First!
Picture of Safety First!
With the coil removed, I straightened the piece of wire that would raise it up from the base. After that, I filed the ends to make them less dangerous and pointy (which I should have done before I wound it!)
Step 4: Test!
Picture of Test!
I clamped the wire in a vice and saw that it did indeed support my soldering iron! Now on to the base!
Step 5: The Base
Picture of The Base
I chose to make the base out of 18mm thick plywood, which should provide plenty of stability. I cut it to size and then sanded it smooth.
Step 6: Assembly
Picture of Assembly
I drilled a hole in the base for the coil to sit in and then secured it using CA glue.
Step 7: Sponge Holder
Picture of Sponge Holder
Using some odd scraps, I made a small space in which I could place a cut sponge to dab the tip of my iron. I secured these pieces with CA glue and sanded it all smooth by hand.
Step 8: Paint!
Picture of Paint!
With everything assembled, I gave the piece a coat of black paint to make it look a bit more professional.
Step 9: Done!
Picture of Done!
With that, the project is finished! I cut a small sponge to fit in the holder and I am absolutely delighted with how it looks and works! I hope you found this instructable useful and if you make one of these, I would love to see it!
-Shaun
JoãoP95 made it! (author)2016-07-31
nice!! taking another idea, i build it ;)
ShaunM11 (author)JoãoP952016-07-31
Well done! That looks great :)
kidintheworkshop (author)2016-07-12
nice ill make one tomorrow and just one idea to make your stand more useful bend a piece of wire to make a solder spool holder post pic tomorrow hope fully
I look forward to seeing it :)
FrancescoL24 made it! (author)2016-07-09
Thanks a lot you gave me the idea :)
ShaunM11 (author)FrancescoL242016-07-10
That looks great! Well done!
harleyjon (author)2016-07-04
The stand you built looks like it could have been the stand from the very beginning. I think you did a great job of making the stand look like it was built for that tool. I also agree that the safety factors come from being aware of your surroundings.
ShaunM11 (author)harleyjon2016-07-05
Thank you very much for your comment! As my dad says: safety first, second and third!
DonSteve (author)2016-07-04
Get the hot tip a cover cap, perhaps just extend the wire holder.
Also you might want to make the holder base a bit bigger and add a holder for a soldering wire spool to be always at arms reach.
However it's a pretty good job.
Thanks for sharing :)
ShaunM11 (author)DonSteve2016-07-04
Thanks for your comment and the suggestions :)
BeachsideHank (author)2016-07-02
It's great you put grandpa's old tools to work but you really ought to rethink having a hot tip unsheilded and hanging out in space like that, there's a reason why commercial stands have a cage as a recepticle.
ShaunM11 (author)BeachsideHank2016-07-02
Hey, thanks for your comment! I do appreciate the fact that the hot tip is an issue, but it's a risk that I have evaluated and am aware of when working in the shop.
About This Instructable
3,467views
81favorites
License:
More by ShaunM11:Leather Stitching PonySwiss Army Knife CaseEnd Grain Coasters
Add instructable to:
