- I gutted the timer
- I traced the timer's back onto a thin piece of cardboard
- I pulled out a lot of the copper wire and formed it into several shapeless blobs of wire
- I stuffed the shapeless blobs into the back of the timer
- I taped the cardboard cutout onto the back of the timer so it would hold everything in.
So now I can refill the cleaner whenever I need to using the same spool of wire I used back then.
It may be shoddy, but in the end it turned out to work pretty well.
Visit Our Store »
Go Pro Today »
The dampness has nothing to do with the cleaning process - that's just the mechanical wiping. The water just protects the sponge from the heat - by cooling the tip as the evaporation of water uses a lot of energy.
Some say that using a fluff of copper or another metal for cleaning is beneficial as the tip stays hotter, so the next soldering point will be of a higher quality. And the tip gets a thermal shock with every cleaning.
I used both methods - and both work. Advantage of the metal: The sponge is almost always dry when you need it, the metal is just ready to go.
Btw: If you strip a cable with a wire mesh for shielding, this wire mesh make a great tip cleaner.
