3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Soldering Station
Step 5Iron holder
Iron holder
The soldering tip needs to be supported within the box to keep the rest of the iron in place. It also prevents the rather warm tip from touching things it shouldn't when resting inside the box. A little metal ring (scavenged from a printer where it kept internal cords organized) was embedded tightly in a small piece of wood. I "friction-fit" the ring as the hot tip would just melt any hot glue adhesive I used (and I couldn't find my superglue at the time). A support block was cut and the ring block and supporting piece of wood were attached together. Experiment to find the correct placement of this assembly within the box. Just put the iron (er, make sure it's turned off) in the hole on the face. Mark where the ring block should go so the tip lies within the ring and glue 'er in place.
1 comment
Sep 15, 2011. 2:27 AMMr. D. says:
Just an idea. Maybe use a hollow brass (or other metal) tube from the "eye" to the support block to help guide the iron.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:StepsoftheSun
