Step 8Mistakes, fixes, and things for version 2.0
I guess the internal layout could have been thought through more carefully...the tip of the iron is a little to close to the switch's wiring. If one's not really paying attention, the tip could be put through the face and potentially hit the wires (melting insulation, messing up the iron's tip, possible electrocution...not good). I put a guardrail in place; it's just a bent piece of coathanger. It deflects the tip away from the wires in cases of bad aim.
Update! PKM suggested I make a wire coil to further protect the box's internals. I had seen this implemented in jaime9999's iron holder but for whatever reason never thought to implement it here. Great idea!
The "right eye" washer began sliding off after the first use of the station since the melting point of hot glue was easily exceeded by the soldering iron. That fix was easy enough, I had found my superglue by that point and used it to reattach the washer.
Remember how I cut that latch slot too long? Turns out it was just what I needed. When packing this station up you can open the top, put the plug end of the extension cord inside and then close the lid, allowing the middle section of the cord to protrude through that slot (I stuff the remainder of the cord into the box at this point). It's actually the only way to store that cord and far better than wrapping it around the station, in my mind.
Improvements
(1) Think of how to incorporate a sponge, maybe on the lid. I think we could do better than just slapping a wet sponge onto the table.
(2) Add wire and wick (desoldering braid) dispensers.
(3) Functional light switch...
comments
Add Comment
wilwrk4tls
says:
Add Comment
