Visit my site at electronic projects
(http://elec.projects.googlepages.com/home)
If you enjoy this instructable please digg it!
Remove these ads by
Signing UpStep 1Soldering iron tip
1 get a new tip. depending on what type of soldering iron you have, you can get new tips. There are many different kinds you can get.
2 clean the tip. if you don't already have one, it's a good idea to invest in a tip cleaning sponge. after each soldered connection, clean the tip on the sponge (after getting the sponge damp). You can also buy soldering iron tip cleaners. you put your hot soldering iron tip in them and it will clean the tip, but there will be a lot of smoke.
1: Power does not equal temperature. A 30W iron is not inherantly cooler than a 40W. In the same way as a ferrari and a mini are capable of 30mph and 90mph, the ferari just gets there faster.
2: Lead free solder does NOT require a higher temperature. What is needs is more POWER in order for the iron tip to remain ata stable temp. 80W is the min for good high speed lead free solder (And the right size tip)
3: @Vspec. You are right Lead fumes are not good. However lead can not be vapourised buy any soldering iron, Unless it reaches 1000's of Centigrade because its faulty. Its the Rosin flux that creates the fumes and yes its not good for you.
Also, I've had the same problem you're experiencing de-soldering analog sticks from controller motherboards. I've tried the vacuum tool and the de-soldering braids, and even made some of my own which worked occasionally.
The best thing I did was buy a better variable temp soldering iron. That helped a lot. Good luck with the 360 mother board.
BTW, did you take any pictures at all? Why the googled images?
example:first touch the iron to the solder then pull them apart after 11/2 counts
References: Solder Fumes and You A British health department pamphlet explaining the health hazards of rosin-based flux fumes (irritation, headaches, dermatitis, asthma) and what precautions employees and employers should take. Note the total lack of any mentioning of lead poisoning.
more explanation Click expand at the end of the sentence "What is exactly in solder fumes? Am I safer using lead-free solder? (no) "
