3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Soldering tips and tricks
Step 4Step four
step four
So now that you know how to make good solder joint connections, you start to solder again. Hmm you think. I wonder if there is more than one type of solder?
1 Yes, there is! There is lead and tin solder, which is 60% tin and 40% lead, and there is lead free solder which is usually tin and silver
Yay! I'm going to use lead free solder, you think to yourself! So you go out and buy some, but for so reason your soldering iron just cant seam to melt the solder. How come?
1 lead free solder requires more heat to melt, so your soldering iron might not be strong enough. 40 watts is enough to melt it, so you can get a 40 watt soldering iron, or higher
2 still not melting? Refer to step one.
4 comments
Apr 12, 2012. 7:19 AMnprince says:
There are so many mistakes here its not funny.
1: Power does not equal temperature. A 30W iron is not inherantly cooler than a 40W. In the same way as a ferrari and a mini are capable of 30mph and 90mph, the ferari just gets there faster.
2: Lead free solder does NOT require a higher temperature. What is needs is more POWER in order for the iron tip to remain ata stable temp. 80W is the min for good high speed lead free solder (And the right size tip)
3: @Vspec. You are right Lead fumes are not good. However lead can not be vapourised buy any soldering iron, Unless it reaches 1000's of Centigrade because its faulty. Its the Rosin flux that creates the fumes and yes its not good for you.
Jun 14, 2011. 4:25 PMVspec says:
luckily i use solder with a 92% lead content so i never have to worry about it not melting. you just have to use a fume hood, lead fumes are no good.
Mar 12, 2008. 12:53 PMfini2 says:
cool dude, i made a pnumatic cannon with copper pipes, this helped alot to "seal the deal". ...ok bad pun...
Jul 10, 2010. 6:04 AMgrk2meet says:
lol seal the deal
Nov 2, 2008. 9:03 PMrivetgeek says:
I sure hope you dont have much pressure in that. copper isn't rated very high for air, but it sure does make great shrapnel
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:Mr. M
