Soldering to large metal objects
Large metal objects inhibit your ability to solder because they draw all of the heat away from the point of...well... soldering? Normally you would either have to leave your soldering iron on the piece of metal long enough to heat the entire thing up to about 800 degrees Fahrenheit (which can take a LONG time), or you would settle for a weak joint and end up hot-gluing or epoxying over it in order to make sure that it won't come off.
However, by following these few simple steps, you can create a strong solder joint and not have to worry about the joint breaking.
Materials:
Propane torch
Solder
Soldering iron (preferable)
clamp
Step 1Prep / Getting solder onto the metal
Clamp the metal so that the flame from the propane torch will not melt/burn anything you have lying around
Light the torch and make the flame really low (see picture).
Hold the torch up to the metal and heat it up.
Be sure to move the torch back and forth so that you don't melt the metal itself.
Every once in a while remove the flame and test to see if you can melt solder on the hot metal.
Once the solder begins to melt, heat the metal up for a few more seconds and then remove the flame for good (you can turn off the torch now).
Quickly apply solder to the hot metal, try to cover the entire area you are going to use.
Don't be afraid to use excess solder, solder is your friend =).
You want the solder to look shiny when it cools. If it doesn't look shiny then quickly heat it up with the torch and let it cool without touching it.
15 comments
May 3, 2008. 1:14 AMGavabc123 says:
i use my 25W soldering iron to weld since i don have a welder
May 3, 2008. 8:10 PMGavabc123 says:
by welding i mean joining pieces of metal together
Apr 2, 2009. 2:12 PMmawktheone says:
so.. you solder. which is a pretty unremarkable use for a soldering iron but if you need to do heavier soldering you can get unpowered irons with really big copper tips. you heat them in a small furnace and use the flat side to join tinned hunks of metal
Jul 15, 2009. 7:46 PMFather Christmas says:
lol. that made me laugh. "...pretty unremarkable use for a..." i couldnt have said it better myself.
May 1, 2009. 4:01 AMUdon says:
Okay, but what about soldering pieces of galvanized wire together? What type of solder can you use? The ending result is jewellery, so it's quite fine pieces I want to join. I have a lightweight blowtorch and a roll of solid, lead-free solder, but it's not cored... can I get away with NOT using flux?
Jul 8, 2008. 6:56 PMSebboco says:
Do you need flux to solder? I have acid core solder.
Apr 20, 2007. 12:37 PMVendigroth says:
i prefer to solder using the torch on its own, but well thought out BTW, you can get little pencil flame torches with soldering iron tips
Jan 20, 2007. 6:28 PMleevonk says:
you can also buy a solder gun (would be cheaper than a propane torch). I've used solder guns to solder really big pieces of metal (really thick cable, maybe six times as thick and a lot longer than the metal shown in the pictures) effectively.
Mar 7, 2007. 10:13 AMleevonk says:
the thick cable I mentioned was not solid cable, it was stranded, I think that makes it easier to solder (higher surface area to accept heat).
Jan 31, 2007. 3:23 PMwittyhoosier says:
There is to be had a contact soldering tip (like the one on your electric iron, only bigger) that you fit to the end of the propane torch. The flame heats the tip, tip heats the joint.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
76
Author:T3h_Muffinator(olopede)
I'm a just a not-so-average human with a passion for making. I see a world of hackers, makers, and producers as the sun rises in the near future. I'm starting olopede, an educational electronics k...
more »
