However, by following these few simple steps, you can create a strong solder joint and not have to worry about the joint breaking.
Materials:
Propane torch
Solder
Soldering iron (preferable)
clamp
Remove these ads by
Signing UpStep 1Prep / Getting solder onto the metal
Light the torch and make the flame really low (see picture).
Hold the torch up to the metal and heat it up.
Be sure to move the torch back and forth so that you don't melt the metal itself.
Every once in a while remove the flame and test to see if you can melt solder on the hot metal.
Once the solder begins to melt, heat the metal up for a few more seconds and then remove the flame for good (you can turn off the torch now).
Quickly apply solder to the hot metal, try to cover the entire area you are going to use.
Don't be afraid to use excess solder, solder is your friend =).
You want the solder to look shiny when it cools. If it doesn't look shiny then quickly heat it up with the torch and let it cool without touching it.
I'd use silver-bearing solder and tons of (external) flux. I've never tried soldering galvanized wire - it will most definitely interfere with the process though. You might want to try and scrape off the coating where you're going to make your joints.
Good luck!
