Solderless Music LED Bottle
6,401
15
Published
Introduction: Solderless Music LED Bottle
About: I'm an inventor and a coder and will try different things for the betterment of ones life
The Solderess Music LED bottle is a music controlled light box that
lights up when the BASS is around ohh yeah!!!
now let's get the lighting started! yeeahhh!
Step 1: Materials for the Light Show!
the materials are as follows:
2 Tip 31 transistor
8 LED's
Aligator pins
heat shrink tubing
TRS audio plug
12V dc source
Bottle
scissors
lighter
sand paper
and a lot of patience...
Step 2: Scheme for the Schematic
Now get your LED's and scrape the tip of their heads to make it look more opaque,
now bend their feet and with the wires insert the heat shrink tubing,
now connect the feet of the led and the wires by twisting them both,
now insert in place the tubing and heat it all up with a lighter,
Now this is the key for this solderless project, all it takes is some heat shrink tubing and a heat source,
now follow the design schematic, and now your finish with the circuit.
Step 3: Enclosure Enclosure Enclosure
Now to prep up the enclosure,
sand the bottle, make some holes and now you're done!.
detailed approach!: after sanding the bottle, drill two holes on top for the input wires,
now drill some hole at the bottom of the bottle for the audio plug,
Step 4: Power ON!
Now power the circuit,
Insert it to the phone and Watch the light show!.
This project was inspired by Kipkay from Makezine.
Great project! Thanks kipkay!
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
