Making Solid Rocket Fuel in the Lab by kentchemistry.com
video Making Solid Rocket Fuel in the Lab
Music: Kevin MacLeod Once used as solid rocket fuel, because the reaction requires no oxygen. Sulfur and zinc react vigorously. The reaction with zinc produces flame and a near explosion. Sparks fly and smoke billows in this dramatic chemical demonstration. Please do not try this one at home.
Zinc is a bluish-white metal used to galvanize iron, and is also found in alloys, batteries, and rubber. Sulfur is a yellow, brittle nonmetal; it can also be found in a powered form. Zinc and sulfur react with each other violently to produce zinc sulfide; the reaction is accompanied by a vigorous evolution of gas, heat, and light:
Zn(s) + S(s) ——> ZnS(s) [one of the easier
chemical equations
to balance!]
The products of the reaction also include small amounts of zinc oxide (ZnO) and sulfur dioxide (SO2).
!!! Hazards !!!
This reaction produces a great deal of heat energy; clear the area of flammable materials.
This reaction must be performed in a fume hood or some open, well-ventilated area. If you do this in a fume hood, be prepared to spend some time wiping zinc sulfide powder off all of the surfaces in the hood.
saucerman says: Oct 5, 2011. 12:11 PM
Correction on weight. The five foot rocket weighed 70 pounds fueled and 12 pounds empty.
saucerman says: Oct 5, 2011. 12:06 PM
I have made several zinc and sulfur rockets and this propellant combination is not shock sensitive and very safe to use. Mix 2 pounds of zinc dust with one pound of flowers of sulfur. For a very fast reaction screen the zinc dust through a 400 mesh screen. I just mixed the two ingredients in a dry state but acetone could also be used if a binder of some sort was used. My rockets used a 2" O.D. seamless steel tube with an .125" wall thickness and a converging/diverging nozzle with about a 3/4" diameter throat. Make the nozzle from copper or brass to improve heat transfer in the nozzle and eliminate erosion just downstream of the throat. Compress the fuel/oxidizer mixture in the tube with aluminum pressing ram. This will eliminate voids and keep the burning surface area constant (this is what's called an end burner). I fired this design perhaps a dozen times with tube lengths from a foot long to 6 feet long. The burn time seemed to be less than a second regardless of the tube length which tells me this propellant combination has a burn rate proportional to chamber pressure. Not a desirable feature so I would strongly recommend some type of inhibitor to slow down the burn rate. The rocket exhaust is a beautiful supersonic stream much like the solid boosters of the Space Shuttle and the sound is very loud. I have been within 40 feet of the rocket when is was fired in a test stand and threw my arms in front of my to face to block out the heat. My five foot long rocket weighed 24 pounds fueled and 12 pounds empty and went about 1200 feet up. A spectacular show. Good luck.
TimmyMiller says: Sep 23, 2011. 5:43 PM
where did u get the sulfur?
TimmyMiller says: Sep 23, 2011. 2:38 PM
send me a message if u can
TimmyMiller says: Sep 23, 2011. 2:37 PM
can u use the by-product for something/
talco92 says: Oct 23, 2008. 1:18 AM
would it be possible to make mix zinc and sulfur in boiling water (make a solution, but make it thick) and let it dry in a mould to create a solid piece of fuel? just wondering and if anyone can help with that question that would be great. cheers
Shadowfury says: Feb 22, 2009. 12:28 AM
Or, melt the sulfur, mix in the zinc, then stir. Then pour the mixture into water to make plastic sulfur, then squish it into a mold, then let it crystallize.
Raydoom says: May 14, 2011. 2:04 AM
zinc is a metal so it doesnt like to mix with water and sulfur doesnt absorb water either , if you tried this, the solids will just simply sink to the bottom of the solution
mr.space says: Dec 29, 2008. 9:39 AM
you could try adding some dextrin with the water, make it crumbly, then compress it into a mould, thats what I do with BP engines... anyone think i should make a Instructable on it?
lobo_pal says: Jan 4, 2009. 6:53 PM
Totally.
milamber says: Dec 30, 2008. 7:44 PM
yeah
Berkin says: Oct 29, 2008. 1:16 PM
That would not be the best idea in my opinion. What you should try is directly adding cold water to the powder mixture until it's a paste, shape it and dry. Or, if the paste is too runny or crumbly, you could try adding a thickener of some sort, like flour. This will make it nice and pliable with the protein compounds in the flour to make it all stick together. I don't think it would hurt the explosive, as long as you let it completely dry before you ignite it.
willrandship says: Dec 22, 2009. 5:39 PM
Flour itself will burn quite vigorously if spread into dust in the air, so I doubt it would cause burning problems.
talco92 says: Oct 31, 2008. 5:56 AM
Alright thanks for that mate. If I end up trying it out I'll let you know how it went. Cheers
supershot1 says: Mar 25, 2011. 8:45 AM
um... I will make it with ethanol!!!!!!
superMacaroni says: Sep 9, 2010. 1:22 AM
Would it work if I mixed garlic and oysters in a blender?
popscott3 says: Jul 3, 2010. 12:17 PM
wow. just wow...in a science camp we made thermite! it was very bright...
fragmaster4 says: Apr 9, 2010. 2:09 PM
Ha ha, at the end it looks like some kind of dark portal =P
GlobalVillageIdiot says: Jan 21, 2010. 2:21 PM
It's my understanding that inhaling zinc oxide (ZnO) will produce flu like symptoms (google " zinc poisoning), which can be fatal within a couple of days.
Kiteman says: Feb 9, 2010. 11:48 AM
...hence the warning about ventilation.
However, ZnS has been used as a hobbyist fuel for fifty or sixty years, and I have never heard of a case of poisoning.
walfers1 says: Sep 23, 2009. 7:40 PM
nice fuel sorce but how do they make the jell rocket fuel?
poop#1 says: Jul 16, 2009. 11:30 PM
all this is ,its just a firework
nonickname says: May 24, 2009. 9:20 PM
How much thrust/energy do you believe this would create compared to potassium nitrate + sugar or commercial model rocket engines?
148wmcquiston says: Nov 29, 2008. 10:47 PM
Would it be possible to make a rocket fuel using sugar, aluminum, paraffin as a binder and some some of oxidizer
Shadowfury says: Feb 22, 2009. 12:30 AM
Paraffin is unnecessary. Make the KNO3/glucose mixture, then as it is cooling, just mix in the Al powder.
MrApples says: Feb 4, 2008. 3:25 PM
Also this has already been posted on another website and its in the exact same format so he just copy pasted it.
mr.dr.prof.joel says: May 13, 2008. 5:05 PM
plagerism
pindalanderz says: May 11, 2008. 6:48 AM
ever thought that the person at the other site copy and pasted it?
Derin says: Jun 19, 2008. 9:32 AM
yes the guy who owns the video is the same guy that copypasted it
Derin says: Feb 11, 2008. 10:17 AM
yea ps kent I'm tr-derin from MetaCafe it is nice to see all the metacafe folks at Instructables!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
