loading
To build a steadicam need
1. Flat piece of sheet metal with a length of 1 m and a width of 30mm.
2. Handle of drill
3. Socket wrench 3/8 inch
4. Washer Screw 28mm - 13 pcs
5. Ball bearing, 12mm inside width
6. Cork mat
7. Knob with M6 screw
8. Cardan joint 1/4 inch
9. Screw the hat with a length of 60 mm
10. Nut with ears M6
11. Angle Grinder
12. Model glue
13. Heat-shrink tubing
14. Knife
15. A little time and patience
16. Clamps
Step 1: Adapter holder and counterweight
M6 nut hit with the force of a socket wrench 3/8 inch. Then arrange all screw washers in the stack, and assumes heat shrink. This is to look in the same way as in the picture.
Step 2: The main element of steadicam
A flat piece of metal that have. We shape in the same way as in the foto. When will shape a piece of metal. Using the center of the grinding cut out thin strips of a width of 6mm.
Dimension strip for mounting the camera - 6mm width, lengths are 125mm < --- It is located in the center of the element. You can see it in the foto
Strap assembly and adjustment handles - 6mm width, lengths are 135mm <--- It is located in the center of the element. You can see it in the foto.
Strap to adjust the load - 6mm width, lengths are 410mm <--- The distance from the bottom of the metal end 20mm. It stretches from the bottom to the top of the length 410mm.
Place the top piece of metal where it will be mounted camera is leveled. After completing all the work we send metal powder coating. If the metal back of the painting, we move on to the next step
Step 3: Rotating handle
Bearing teamed with cardan joint and fastened in the holder as foto. In such a way that the bearing mounted on the rotary movement allowed Cardan 1/4 inch. Bearing the handle is glued to the glue. Next step
Step 4: The camera bracket
We take the cork mat. We measure the upper part of my metal where the camera is mounted. Then cut a piece of dimensions such as the upper part of the steadicam. We cut a hole in the middle of the cork mat for the screw 1/4 inch. Check to see if it fits. Next step
Step 5: The camera bracket 2
After matching a piece of cork mat smear her modeling glue in the same way as in the picture and glue it to the top of the steadicam. After sticking the cork mat lined with pieces of wood and vice clamps. Leave for several hours to dry. Next step
Step 6: Installation of movable handle
Tighten the holding fixture put in the middle part of steadicam as in the picture and screw cap with pressed nut M6. Cap and cardan pasujądo each other and can be removed by fitting 1/4 inch. We combine the handle and move on. Next step
Step 7: Installation of counterweight
Counterweight to assemble using the screw with a hat with a length of 60mm and screw cap with ears. The counterweight is adjustable over the entire length of the cut hole with a screw. Each counterweight should be determined individually for the camera. Counterweight can be quickly disconnected by a screw, does not cause a problem in the area. I made a few weights to the various cameras and wear them with steadicam in a case. All are made of washers and joined shrinkable sleeve. Next Step
Step 8: Ready steadicam
If you followed all the steps well, and you are smart you were able to do steadycam worth 600PLN = + / - $ 200. If you liked my project and have questions write to priv. This is my first project on this page. Please bear with us. I'm from Polish.
The next tutorial will execute more precisely since the construction of the steadicam did not have much time.
In the next tutorial will arrange slide to timelapse.
Below a link to my gallery of my photos. Feel free to like and comment
https://www.facebook.com/wwartfoto
If you interested in cooperation. Write on priv. We perform a joint project
<p>I made this, but I am not sure I can recommend it.<br><br> I found that there is some strange movements from the steadycam, that I think came from the cross coupling of the 2 axis from the Cardan-Joint. The 2 rotational axis of the Cardan-joint are slightly offset(1/8~1/4 in.), which when the handle are move or twisted, the camera will move unpredictably, I think it is because the CG shifts and don't align with one of those axis when the handle is moved... Think this will be better if it use a true Cardan-joint, then all 3 of the axis intersect at a point.</p><p></p>
<p>Thanks for the tip!</p>
<p>In my everything is ok. Looking at the performance of your do not have any heart nothing in performance. Your performance is simply not aesthetically pleasing and accurate. Look at mine. I'm a man thoroughly, and if I create something I try to do the best I can.</p>
<p>Hello, <br>Steadicam built for the tutorial I got the code for a premium account for 3 months. I will give the code for free because it is unnecessary to me the person who invited the largest number of people to like my page, which is below the. If the page reaches 1,500 people. I will add a new guide on how to build a studio-class softbox.<br><br><a href="https://www.facebook.com/wwartfoto" rel="nofollow">https://www.facebook.com/wwartfoto</a><br><br></p>
<p>ESPA&Ntilde;OL: Muy bueno ! me voy a hacer uno, no entiendo una cosa, dentro de la manija va un ruleman &lt;- (Ball bearing) ? y el (Cardan joint ) dentro de el?</p><p>Perdon por el ingles, soy de argentina y no se mucho ingles. gracias !</p><p> INGLES: Very good! I'll make one, do not understand one thing, inside the handle goes a ruleman &lt;- (Ball bearing)? and (Cardan joint) into the?</p><p>Sorry for the English, I'm from Argentina and not much English. thank you!</p>
<p>Very elegant and efficient project. </p>
<p>Would you be able to make a video to show how well it works? We also would like to see the camera mounted on the stabilizer when you move it... to see if it really is stable.</p><p>Czy byłbyś w stanie zrobić film, aby pokazać jak to działa? Chcielibyśmy także, aby zobaczyć kamery zamontowane na stabilizator po przeniesieniu go ... aby sprawdzić, czy to naprawdę jest stabilny.</p><p>Thank you,</p><p>Dziękujemy,<br>Jerry</p><br>
<p>Would be good if you could post some video shot using this.</p><p>I would like to see more details of how you bent the bar to shape.</p>
I'll record a video of the operation as I get home. Now I'm out of the house and steadicam was also in the house
any footage to see how well it works?
Thanks!
Pshek
<p>English would be awesome</p>
<p>Already is. Better and more accurately.</p>
Brilliant ! I wish it was in English but the pictures should be more than enough!
<p><a href="https://www.instructables.com/id/Solid-Steadicam-below-20-GoPro-vdslr-dslr/" rel="nofollow">https://www.instructables.com/id/Solid-Steadicam-be...</a><br><br>The project improved and made better and more accurately. Today I found the time to complete</p>
I'm sorry, I forgot to change the text ... Tomorrow I will change to English.
<br>Excellent design,they are $100 in amazon this looks like a fraction of the cost
<p>At home, we can do much better and cheaper. Feel free to me will be more. Next project slider for timelapse</p>
About This Instructable
91,929views
635favorites
License:
Bio: I am a young ambitious man. I like photography, survival, sports and many other things. I am an electrician and computer scientist. Free time I ... More »
More by survival434:Solid Steadicam / steadycam below $20 GoPro , dslr, vdslr The cheapest and best steadicam on Instructables
Add instructable to:
