I first thought about making this when I saw an LED clock covered by a wood veneer . I liked it when I saw it, until I saw the price. This is when I decided to build my own, I wanted it to build it for much less, from solid wood and play games!
Remove these ads by
Signing UpStep 1What You Need
- 4, 18" x 4" x 1" wood planks (I went with Maple)
- 85 Red LEDs
- 85 Green LEDs (Optional)
- 1 4 to 16 pin Demiltiplexer
- 15 NPN transistors (such a 2N3904)
- 1 ATMEGA168 Microcontroller (or Arduino)
- 1 20 MHz Crystal
- 1 5 Volt Regulator
- 2 220uF Capacitors (for power spike leveling)
- 1 Old Pocket Radio
- 2 1/8" Audio Jacks
- 1 5-9V DC wall adapter
- 1 (or more) Old Game Controller(s)
- 4 3-1/2" Wood Screws
- Solid Core Wire (easier to work with)
- Solder
- Hot Glue Sticks
- White Glue
- Sand paper
For the game controller I use an Atari 2600 joystick (or even paddle if you re-program), but it is also compatible with with a Sega Master System Controllers, Atari 7800 joysticks (theoretically) or even Sega Genesis Controllers.
Tools:
- Drill press
- Flat End Hobby Tool Bit
- Soldering Iron
- Hot Glue Gun
- Miter Saw
Mine is IBM thinkpad R50E. Yay I always thought I'm the only one in the world that owns that laptop.
but it is i nice idea to use less tools for a project
i really gonna build this clock
I think I'll use 3mm RGB leds...
First of all congratulations for that cool project! I just have one basic question. Attached here there is an example of two LEDs that I might want to switch on. They are inside a green oval.
From what I understand, for switching on those two leds, I might have to activate the Pin1 to select green, and Pin11, Pin12 to select those two rows. In order to make the current flow, I guess I might activate the 00 and 01 inputs of the demux by choosing the corresponding pin2to5.
But the problem is, how do I avoid that the leds in red ovals do switch on?
Thanks!
http://www.insidetech.com/nfs/insidetech/attachment_images/0005/5950/american-flag-2a.jpg
The ATMEGA168 should be available there. If not, you could probably order it online from overseas.
If you are going to switch out chips I also suggest you get an AVR ISP mk II to burn a bootloader to the new chips.
On the page discussing electronics setup.. why is it that when you show the solderless breadboard, I don't see any transistors, but they're on the soldered board? If I understand correctly, the set of 15 transistors are only necessary if I want to have two different color LED's on the clock. So this means that the pictured breadboard config will run the clock with just one color?
It'd be soo helpful to get a more detailed shot of the breadboard + Arduino setup.. pretty much because I only 50% understand all of the electronics lingo at this point. :-)
Again - amazing job on this thing!
