Step 3Finish the Front Board
Start by putting the hobby tool bit in the drill press (make sure to leave over 1" out of the chuck).
On a safety note, this is not how the bit is designed to be used, and is a hazard, so be extra careful. Adjust the depth gauge so the bit is barely above the lower board as in the 3rd picture.
Line the bit up with a test hole and gently hold down for 1 second and let up. Hold it down for 1 second again then let up and turn the drill off. The drill is turned off so you can scrape any build-up off of the bottom of the bit. If you don't, it will burn the hole making the face discoloured. Repeat this until you are happy with how much light shines through (see pictures below for a reference).
Once you are comfortable with drilling the holes, move on to the final piece of wood and drill out each hole. Be warned that this takes patience, don't rush it or you may burn out a hole and have to restart.
comment
Add Comment
jwilliamsen
says:
Add Comment
