Solid Wooden Sunglasses
46,100
950
31
Posted
Introduction: Solid Wooden Sunglasses
Mid last year I made these sunglasses and I thought I would share them here. Check out the video above to see how I made them! Thanks to my beautiful baby sister for kindly modelling these! It's much better than seeing them on me.
Step 1: The Lenses
First up, we'll need some lenses. I ripped some out a plastic pair of sunglasses I got free!
Step 2: The Templates
Using the original sunglasses I produced some 1:1 cutting templates. If you are using similar sized lenses you can download the ones I used from my website: http://thiswoodwork.com/making-wooden-sunglasses-summer-woodworking-project/
Step 3: Attaching the Templates
Next, the templates are stuck to the rough blank with a little wood glue.
Step 4: Cutting Out the Frames
Using the scrollsaw the frames are cut roughly to shape, If you don't have a scrollsaw you can do this by hand, it's just going to take a while!
Step 5: Cutting the Frames 2
To cut the opening for the lenses drill through the blank and thread through the blade. Leave the cavity slightly over-sized at this point.
Step 6: Cutting the Temples
The temples (or arms) are cut out in the same way.
Step 7: Fitting the Lenses
Align each lens properly and trace around them with a pencil. Sand close to the marked line, leaving a small rim just under 1mm (IMPORTANT) I used a drum sanding attachment at the drill press to do this.
Step 8: Shaping
The final shape cannot be achieved on the scrollsaw, so using a small handsaw cut away the remaining material and use a hand-file to shape. The original sunglasses serve as a good reference when doing this.
Step 9: Shaping 2
Using sanding attachments, sand to the final shape. (If you don't have these some careful filing and sandpaper should work.)
Step 10: Fitting the Lenses 2
Now to cut the rim for the lenses. Using a rotary cutting disk mounted in the drill press for ease, I cut a shallow groove around the edge of the lens cavity, for the lens to slot in to. This will take some care and a bit of trial and error, but should work if you are careful.
Step 11: The Hinges
Next is the hinges. I could have made some tiny wooden hinges, but it was far easier to cut them off of an old pair of cheap plastic ones!
Step 12: Fitting the Hinges
To attach the hinges mark the position and cut a small cavity on both the front and temples of the glasses. (I used a small drill bit to do this.)
Step 13: Gluing the Hinges
The hinges were glued into the cavities with some quick-set epoxy.
Step 14: Applying the Finish
Finally a finish can be applied to the glasses, before the lenses are pressed into place. For a finish I used mineral oil just to be safe, but I am sure that some spray lacquer would be fine too!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    31 Comments
    what kind of wood did you use and where do you recommend we get it?
    Well done! You should treat yourself and those frames to a nice pare of polarized lenses! Its a disgrace to use the cheep ones in when you've crafted the rest of the sunglass so nicely! Great cheep project though.
    Do you know where to buy the polarized lenses for this style of glasses? I can't find any for under $30
    They are great but knowing me I would either leave them in the pub or sit on them -- cue heart broken!!
    Definitely gonna try to make these this summer, but with actual lenses since I have terrible vision :P These are so cool!
    You glasses looks grate:) i like that they are crafted by hand ( no cnc).
    Could you do these with regular glasses?
    Yes. Same principal, just be far more careful with the real lenses.
    Just don't forget that prescription lenses factor in pupilary distance and have a focal point... there's a lot more precision required than for non-corrective lenses.
