3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solid-state Halloween controller and how to build a Haunted House
Step 7Write the code
Write the code
Once you have made soundtrack, write the controlling code. Here’s a C code fragment to help get you started (check http://www.hytherion.com/beattidp/comput/pport.htm for information on using inpout32.dll) : halloween.cpp, below. Once the sequence is started, the computer plays the soundtrack and syncs peripheral devices through the controller. In this particular setup, which uses the halloween2002.wav soundtrack mentioned above, I would explain to trick-or-treaters that they came just in time to witness an execution. After some thunder and lightning, a small motor would trigger the blade of a guillotine, built from cardboard, aluminum foil, and modular extrusion (8020, borrowed from work) to fall. As a rubber mask stuffed with a pillow fell into a basket, warm water sprayed onto the trick-or-treaters resulting in shrieks, shouts, and frantic brushing to remove the “blood.” I then offered candy from a basket with a duplicate mask stuffed with spaghetti, tomato sauce, and beets. Everyone choose the candy. While this sequence ran open loop through pre-programmed maneuvers, adding feedback to make the display responsive to sounds or motion is quite doable.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
702
Author:ewilhelm
Eric J. Wilhelm is the founder of Instructables. He has a Ph.D. from MIT in Mechanical Engineering. Eric believes in making technology accessible through understanding, and strives to inspire others ...
more »
