One of the first challenges the novice snake-user encounters is unrolling the snake. I'm actually planning on doing a separate instructable-tip for that process. But suffice it to say that you need to hold onto it VERY TIGHTLY and carefully walk out the entire length of the snake (stepping on it as you do so to keep it from sproinging out of control) and then re-coil it with a much larger diameter. Secure the larger coil by wrapping one end around the coil thru the center of it several times so that it locks against itself.
Remove these ads by
Signing UpStep 1Avoiding major trauma -- keep the end folded over.
Take the end of the snake in the grip of a pair of pliers and bend it over 180 degrees. Then crimp it down tightly, so that the sharp end is no longer exposed.
The loop on the end is also useful for hooking the snake at the far end when you are snaking in walls or ceilings and for providing a place to securely tie on wire or whatever you're snaking. Twist it through the loop and then cover the whole thing with electrical tape to keep it from snagging and to help keep it secure.
Electrician Oakland
