3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
"Something weird is going on here" (Joe Pipe - Free energy)
video "Something weird is going on here" (Joe Pipe - Free energy)
This is from my friend Joshua. It's on Youtube and he has many more videos there to share with everyone.  Just type "Joe Pipe" in the Youtube search box for more.
30 comments
Mar 8, 2010. 9:49 AMfrollard says:
So...lighting fuel on fire produces heat.  Gotcha :D
"Imagine what would happen if you added oxygen...or steam"
the exact same thing, just at a different speed.  Energy in = energy out.
Mar 9, 2010. 12:58 PMjoshualight says:
 Hi frollard
   Good to hear your comments.
    The endothermic reaction tends to manifest different anomalies even when the test procedures are identical.  Still searching for the missing variable that trips the combustion process to shift from 3rd to 4th state.  It seems to have something to do with the vortexing of the endothermic reaction.
   In the plasma state, the Btu release of energy is much greater than the nominal state.  Like comparing a hand held propane torch to a plasma cutter using exactly the same amount of fuel.
    It is not just a shift in the energy itself, but may have something to do with a physical shift of the fuel or matter that causes the super state to manifest.
     Or it could be that when the plasma state is reached, it produces a resonance harmonic or sub harmonic that opens up a wormhole to the universal vacuum energy.  A shift from the quantum to the scaler state.
     Propane tends to produce the nominal state but have seen it produce quantum reactions using titanium and ceramics.  Could be the densities of the matte that generates a feedback harmonic mixed in with the harmonic generated by the joepipe itself.  Same kind of concept used in the Philadelphia experiment.
     At some point I would like to duplicate the initial results of 5 years ago using a multiple of various self generated fuel vapors.  Gas and water tend to be more anomalous than propane.  The first time I witnessed copper going into the super conductive state and melting titanium by direct contact with the metal blew me away!  You don't read about stuff like this in conventional science.   But I've seen it time and time again.
     It is more than possible to convert 3rd state matter such as propane into an electrically induced matter state.  And when this 4th state matter com busts, this is what generates the various anomalies that may be considered to be of the 5th state of matter?
   Last fall I tested .5 inch quartz tubing and got it to melt stainless steel screen with NO oxygen!  That's around 2, 600 F.  When O2 was added, it increased the speed of the overall reaction with a minor increase in heat.
     Was not set up to add steam at this point, but will have all the safety parameters set in place for the firebrick tests.  According to the super heated steam tests done by Sir Hoax on u tube, heating steam into superheated steam will burn when it oxidizes with O2.  The released hydrogen should boost the Btu output of the joepipe, or it could trigger the super state.
    With this next setup, it will be easy to see what happens when combinations of water and waste oil is injected into the concentric gap.  I'll modify the fan to catch the back pressure and add a secondary air flow into the gap to create a direction of flow.
    If the key can be found to shift matter from the 3rd into the 4th state, then the energy out would be over unity being in the plasma state.  Shifting from a liquid to a vapor is no different that phase changing matter.  We just need to understand it to harness its secrets.  So there really is no shortage of energy in the world, not if matter can be shifted.  This would also end pollution as we know it.  In fact, greenhouse gas would become a catylist for the plasma state.  Keeps things interesting that's for sure.  I'm not one for thinking inside of the box.
Mar 12, 2010. 2:29 PMNachoMahma says:
.  Word salad. nom nom.
Mar 12, 2010. 4:02 AMKiteman says:
"Still searching for the missing variable that trips the combustion process to shift from 3rd to 4th state"
That's called "fire".
Mar 12, 2010. 10:35 AMjoshualight says:
 Hi Kiteman-What I am saying here, is at times the combustion process shifts out of the 3rd state of matter.  It would be like taking a blue bottle propane torch, and seeing it transform into a full blown plasma cutter.  And not just a few inches or so.  The plasma ejections I'm seen were at least 10 inches in length and 1.5 inches in diameter.
   Saying that it is fire is true.  But this tells me nothing about how the matter shift took place.  Energy is everywhere in the universe just vibrating at different frequencies.  Is it possible to generate some resonant energy signature that is a harmonic to a quantum field energy?  Just like how one tuning fork will tune another without touching.  Over unity is a misnomer.  It has been known that free radical electrons will generate energy out if you alter their spin.  Or if enough imbalance is set up, maybe cause them to leave orbit altogether.  Now this would cause some fun to happen.
Mar 12, 2010. 11:14 AMKiteman says:
" Saying that it is fire is true.  But this tells me nothing about how the matter shift took place."
Yes, it does; it caught fire.
The size, shape and colour of the flames is utterly irrelevant if you have not measured the energy through-put, including the mass-flow and temeperatures all round.
That stuff about "resonant energy" is nonsense, peddled by charlatans and snake-oil salesmen, believed by those who have not bothered to look into the actual facts.
Overunity is exactly what you are claiming - if you are claiming "free energy", you are claiming to get out more than you put in.  This has two names; overunity and impossible.
Mar 12, 2010. 1:28 PMjoshualight says:
 Hi Kiteman-Wished at the time when I witnesses some of these anomalies that all the test equipment was in place to measure date.
   Another observation that I saw using the titanium pipe you see in the pics.  Is that in the first test using titanium and propane, the metal did not change color.  Not even a hint.  You can tell the rough temperature of internal flame by the color or the metal.  Don't need a tester to tell your that.
   However, when a short length of .5 porcelain tube was inserted half in and half out of the titanium test pipe, this generated a super bright lime green flame external of the pipe about 3 inches or so.  After a minute or two, 2/3's of the titanium pipe glowed a very bright orange-white.  Bright enough to read a newspaper in the dark.  In all my testing, not once did I ever get a titanium pipe to burn with this kind of intensified color change.  So where did the extra energy come from to account for the change?
    I could have run this for hours it seemed, but at the time I shut off the titanium pipe and went for a coffee. Went I came back it was cool enough to examine,  And to my surprise, you could see hundreds of pot marks on both sides of the pipe.  This again has never happened since then.  Propane doesn't produce that kind of heat to physically pot mark the titanium.  Went I took the piece in to the coffee shop, my friend took one whiff and said that there was a strong arcing smell.  Now you know that this was because the temperature was high enough to reach the vapor point of the metal.  And the pot marks, they were perfectly spaced apart on the surface.  This is not the normal burn of propane and air.
   It is my best guess that the excess energy came out from the atomic valence of the titanium itself.  The porcelain could have set up some kind of cascading effect that began to set into imbalance the outer shell.  If you split the nucleus you get a really big bang of energy release.  Maybe this was happening without the nucleus being split, but influenced by the valence imbalance.  It is a fact that energy being that produced by the burning of the propane came from somewhere.
    You know in the Montock project, they perfected a jump chair that was able to dial up the frequency of the space-time location you wanted to go.  Hyperspace is no longer a theory and has been used in the upper military circles.  Sound I believe has everything to do with want I'm doing here.  It is the common denominator seen in a number of the super state reactions.
    In around the same time I discovered the joepipe technology, I met this man who was third party to a test group in Calgary, Alberta.  They were involved in what was called the 'Jackhammer effect.'  This group from what I was told, were able to dissociate water into hydrogen and oxygen using sound induction at a pressure of 2, 700 psi.  When news of this got out, big boys came up from the US and shut down the project and did a internet sweep of all information.
    There is also a man here in Mission, BC, who has a patented device that using sound to induce freezing.  So if sound can have a freezing effect, it can also have the opposite effect.  Most of what we are used to is the third state of things.  In the 4th state matter takes on a higher state of energy.  Not more energy.  Just more energetic but more energy as it would have in the third state.  Same as steam is more energetic than water.  The same amount of matter but in a different phase change.
   It is evident that the characteristics of the metal observed in the super state is a result of a change of matter from a lower to a higher state.  There can really be no other reasonable explanation.  No magnets were use to induce the change or anything else.  It is proven that a little energy can cause H2 to divide into H1 + H1, and when it combines back into H2, that the shift releases over 5, 000 F of heat.  Again there was a shift in the molecular state of the matter.  Then you look at Tesla's work, John Keeley, Hutchenson, Brown and others.  They all had one thing in common, and that was energy was being pulled in from an outside source.  Then you have Paul Pantone and his ability to transmute matter which has been proven but not understood or accepted even with the facts.  Very little is understood about implosion dynamics.  The perfect device would use both sides of the coin at the same time to really be efficient.  Matter changing states at a exponential rate.
    Anyway, I'l do what I can here to post some work and use the forum to communicate here.
Mar 12, 2010. 2:23 PMKiteman says:
Oh dear, all my woo woo alarms went off at once when I read that.
I am sorry you have succumbed to just about every strain of conspiracy theory at once.
Montock project?  None of the conspiracists can even agree what it is.
Jackhammer effect? Try it's proper name; acoustic cavitation.  It's a medical tool.  I don't recall my youngest son exploding in a hydrogen/oxygen fireball when the doctors used it to shatter his kidney stones.
Internet sweep?  So how did you find out about it...?
There's a conspiracy, and I can prove it!
Go on then.
I can't, They have hidden all the evidence!
So how do you know there's a conspiracy?
There must be a conspiracy, otherwise They would not have hidden all the evidence!
But how do you know they hid it?
Because it's not there!
So, your evidence for the existence of a conspiracy is the fact that there is a complete lack of evidence for a conspiracy?
See!  I told you!
There is no point continuing this discussion until you stop making up terminology, flush the woowoo from your psyche, and do a proper examination of your system.
Get the hard data, use proper terminology, and then we can discuss why you have not actually bent the nature of reality, and just made a mistake in your interpretation of the evidence.
Mar 12, 2010. 8:19 PMjoshualight says:
 Hi Kiteman-Some time ago I got to be personal friends with someone who used to work as a guard in area 51.   Stuff that that's way outside the box of conventional thinking.  But i will do my homework here and brush up on my terminology.  As of yet no one has come forward to even give there explanation of the observations presented.  Like copper turning a translucent orange where it turned the end of the titanium pipe into so much sludge.  Copper melts at around 1, 950,F and titanium around 3, 200 F.  So how in the world did something like this happen?  I've not received not one even reasonable explanation as to the facts observed.  So now the ball is in your court to try to give a scientific explanation as to how these said observations were derived.  It has nothing to do with terminology here. At least I've come forward with a possible explanation.  How many of you have seen copper remain in the solid state and melt titanium?  Even had a witness to the fact when it took place.  Just presenting the hard evidence of observation.  I'm not out to be difficult, but up until now, no one has been able to come up with an possible scenario.  Just relating the observable facts here.  You guys are supposed to be the ones with the answers so I'm challenging you up on it. If you want I could send you some of the test samples that got destroyed in the testing so that you can examine for yourselves?
Mar 13, 2010. 6:47 AMNachoMahma says:
.  Au contraire. It is your job to provide evidence that your observations are correct and mean something. "Extraordinary claims require extraordinary evidence" - Carl Sagan (1934 - 1996)
.  Who you gonna to believe, Science or your lyin' eyes?
Mar 13, 2010. 1:04 AMKiteman says:
Translucent copper?
Show us.
Solid copper melting titanium?
Show us.
How do you know it was pure copper?  Pure titanium?
How do you know what the temperature was?
And the assertion that titanium melted is not evidence of overunity (free energy).
Do the measurements.  Get the hard data.  All you have so far a purely subjective, unscientific, inaccurate assertions, plus a deductive leap that is not supported by the premise.
Mar 8, 2010. 12:43 PMNerdz says:
Your forgetting one thing, H2O Reacts with Iron.
What do you mean "greater combustion"? A higher Flame Temperature does NOT mean you get free energy, it just means youve reached a high enough temperature to ignite that gas. In some cases, you can split water with extreme heat and ignite the  resulting gas.
Plenty of Reactions give off More Heat than what was started with, case and point, a thermite reaction. At first it may seem like you are getting more energy than you put in, but down at the atomic and molecular level, electrons are being pulled apart in a chemical reaction, and this reaction releases energy.
Energy in does equal energy out UNDER ideal conditions. That is, if efficiency is equal to 100%, however all is not ideal in the real world. The most you can possibly get is 99% efficiency, and even that is hard to obtain.
Mar 8, 2010. 10:47 PMjoshualight says:
 Hi Nerdz-I understand what you are saying.  The normal operation of the joe pipe where a endotheric-exothermic reaction take place, ie. the Level 3 Flame, stands within the borderlines of conventional science.  However, there is a flip side that is very abnormal, and seems to border in the 4 th state of matter and maybe developing some kind of 5th state wormhole.  On many occasions I've seen the endothermic reaction collapse into pure plasma, seen titanium transcend into the super-conductive state, seen where propane converted into a plasma fuel with multiple colored arcing, seen fire brick instantly go glistening white within a split second,.  These are some of the anomalies I've witnessed firsthand over a five year period of testing.  As far as I understand, no one has yet been able to achieve a matter shift from the 3rd to the 4th state.  This is the nuts and bolts of the anomalous side.  Completely out of the box stuff!  Maybe you could comment on this and I've come across no one at this point who has a reasonable explanation?  Tesla, Brown and others in the same line of thinking were moved by their intuition more so than intellectual knowledge.  I've got samples of titanium that shattered where the Level 3 Flame went into a super sonic mode and created this intense plasma arc that quaked around and dismembered the pipe.  Never seen this in the physics books!  But I have witnessed the 4th state on numerous occasions.  Imagine being able to control and generate the entire scale of the plasma state?  Looking for your response,  Joshua.
Mar 9, 2010. 9:51 AMNerdz says:
Plasma is just super heated energy. Of Course you can Control it. Its done everyday practically. Just use electromagnetic fields or magnetics. Im pretty sure this is how ion thrusters work, by directing a jet of plasma causing thrust.
Do you have calculations to Prove any of these claims? Or Measurements?
Mar 12, 2010. 4:04 AMKiteman says:
Plasma isn't energy, it's just the fourth state of matter - all flames are plasmas.  Nothing special about a plasma.
Mar 12, 2010. 10:49 AMjoshualight says:
 Hi Kiteman-Please let me understand what you're saying here.  Maybe I should rephrase my question.
    The different between propane burning in the 3rd state and propane burning in the 4th state is like comparing gun powder to C4.  Same amount of matter but much more active in the plasma state.  I've seen propane up close converted into the 4th state of matter.  It had multi bands of color and was definitely arcing  as it generated this super white hot spot.  Now where do you see something like this ever happening.  I've used to cut steel and now this is not a conventional situation here.
    And how about the copper when it became thermally super-conductive and turned titanium into sludge upon direct contact with the metal.  Where do you read about this in your science books?
     The very first anomaly I every witnessed doing the fire brick tests, was when I pulled back the brass gas feed and saw a spinning ball of purple light.  It vaporized the bottom of the fire brick and turned it into so much green glass.  The flame itself from observation was a plasma ball and not a linear flame.  You guys are supposed to be the bright ones here.  Still waiting for some reasonable explanations.
Mar 12, 2010. 11:20 AMKiteman says:
I assume you mean "gas" and "plasma".  The difference is that the former is a gas, and the latter is a flame.
You have no evidence for free energy or unusual states of matter at all.  All you have done is set up an efficient flame.
How do you know that the copper became "thermally super-conductive"?  What does that phrase even mean?
Even titanium will melt and react with other hot materials, especially when exposed to the air.
You say you want "reasonable explanations".  Based on the evidence you have given, you have had all the explanation you need; it is an ordinary flame.
Until you provide the data I mentioned, there is nothing else to explain.
Mar 8, 2010. 6:34 PMfrollard says:
+1.
Disassociating the water into h2 and o2 costs energy.  it COOLS the reaction to split them.  further recombination thru a combustion reaction re-releases the energy later down the line - but its energy that you already spent - NOTHING is free :D
Mar 10, 2010. 10:43 AMKiteman says:
I don't see free energy.
I see a flame in a spinning jet of gas.
The nearest I see to a measurement of the energy input or output is "I'm getting baked", with "a level three swirl".  Yet he claims a "30-40% increase in BTU".
Of course he has a swirl - the gases are being blown in by a rotary fan.  Nothing to do with the washers.
Give us mass flow-rates, energy out-puts, electrical power to the fan and pumps?
This is no breakthrough, it's a bloke who likes burning stuff in a pipe.
Mar 10, 2010. 4:58 PMjoshualight says:
 Hi Kiteman-In one of the early tests using 99% alcohol, a 4 x .5 inch copper joepipe developed an ejection of plasma 1.5 x 10 inches in diameter.  Normally, the endothermic burn of the Level 3 state inside of the pipe gives off some exothermic flame but very little in this particular test.
   Anyway, something triggered the normal operation to go into this plasma state from the 3rd state of matter.  No electrical used here?
  What I did as I was not set up to contain this kind of heat, was to turn on the water vapor flush and turn OFF the alcohol.  Right?  Guess what?  The plasma ejection continued to burn unchecked for a full 10 seconds afterwards.  How how can a conventional alcohol flame jumps states like this.  The copper became thermally super conductive as a result of the plasma ejection.
   In a similar test using spinning fire inside of a cored out firebrick, the flame went into the super state, and my heavy brass feed began to melt because of the back-heat.  Turning everything off, the firebrick in the core was a glistening white hot.  Like sunshine shining brightly on snow.  The interior wall get an orange color like you would expect in a kiln.  But to jump into white heat within a split second!  You tell me what's happening here?
Mar 12, 2010. 11:24 AMKiteman says:
"An ejection of plasma" means nothing - a candle-flame is plasma.
Why do you call flames "endothermic burns"?  Fire is exothermic.  That's how we define burning - an exothermic reaction occuring in the plasma state.  If it's not plasma, it's not flame.
What you must do, to support the claim of overunity, is mass and energy flow monitoring.
  • Calculate the actual mass of the reactiont flowing into the system.  From that, calculate the potential energy output using normal chemical models.
  • Monitor the actual temperature of the flame (size is not a measure of energy, and colour is only useful to show the chemicals in the flame).
  • Monitor the actual temperature of the equipment - temperature drop of the gas cylinders, temperature of the pipe.
  • Monitor the energy input of the pumps etc.  Swirling is not a surprise in your set-up, since you are using a rotary pump to inject the gases.  Laminar flow would be a surprise.
At the moment, all you can reliably claim to have is a bright, hot flame, with a visual appearance typical of the normal combustion of hydrogen.
To reiterate: your obsession with plasma is mis-placed.  Plasma does not require electricity to exist.  Plasma is the natural state of matter in any flame.  You must account for the energy in, and the energy out, all of it, before you can make a valid claim for overunity.
Mar 9, 2010. 12:29 PMStoned says:
What you have here is cool, but it is not a free energy device, because they do not and cannot exist. I think you should google "free energy and thermodynamics" because the fundamental laws of thermodynamics state this. Energy/matter/anything is always conserved. Nothing is created nor destroyed, it just changes state. Do not think that I am trying to be mean because I do think what you are trying to do is cool, but I would rather you call your device something else other then a "free energy" device because they are the biggest joke in the science world.
Mar 11, 2010. 5:51 AMdrawe21 says:
Man will never fly.
Titanic will never sink.
Never say Naver...
Mar 10, 2010. 4:48 PMjoshualight says:
 Hi Stoned-Thanks for your reply.
    Just wondering if it is possible to shift a propane and air mix into the plasma state without an outside source of energy such as electricity?
Mar 8, 2010. 11:14 PMjoshualight says:
 Hi frollard-Guess my reply didn't take the first time.
   Anyway, about the cooling effect, the joepipe generates so much mass heat both directly and indirectly that this shouldn't be a problem.  If will be easy to use the direct heat to maintain a large chunk of iron just under the melting point, while at the same time using the concentric gap of the chimney to generate super heated steam at full expansion.  My goal is to use this as a slave unit to drive a second joepipe setup running on a mix of hydrogen and methane by adding some waste oil.  The concentric gap will be way past the melting point of copper and likely reach the melting point of stainless steel.  In previous test, super heating the air and propane causes the flame to manifest signs of thermo-electric characteristics.  Several years ago, adding oxygen to a pipe running on super heated air and propane generated a flashback that ignited the end of the oxygen into an electric arc. So it seems that the thermal reaction is the low end with the electrical potential being the mid point then of course you have the light at the top end.
    Looking to test hopefull next week.  Should prove interesting.  Hoping to get a solid hydrogen combustion.  Could even get a H2 to H1 split then back into H2.  Now that would be something!?  Getting some good response at last.  Thanks.  Joshua.
Mar 8, 2010. 11:01 PMjoshualight says:
 Hi frollard-I understand what you mean.  I've already tested a insulated chimney using T 3100 firebrick to insulate in the heat generated by the joepipe using a 1 1/4 titanium pipe.  The concentric gap was hot enough to bring the titanium to the yellow point.  In and around 2, 500 F.  Hot enough to melt stainless steel wire.
    Pumping all kind of water into the concentric gap had little cooling effect as there was so much mass heat soaked up by the firebrick.  Your talking high kiln temps here.  That was as far as I got last summer.  The whole setup was encased in a plywood wrap, and the super heated air in the cracks of the firebrick was hot enough to char the wood.  Spraying in waste oil instantly converted into fuel vapor and ignited outside the brick.
    Anyway, I've made a second chimney and cored out the firebrick and poured a refractory center.with a 5 inch bore.  Should be interesting this time round as the heat loss is now iliminated for maximum absorption, and this should raise up the core temperature.  With the joepipe back set into the chimney chase, I'll be using the direct flame to heat the iron to just below the melting point, and the side heat of the pipe to convert water into super heated steam at around 2, 500 F.  The supplementary hydrogen split from the steam should produce a substantial amount of Btu's.  Just maxing what I have.  What I'm trying to do here is to create a slave unit to drive a second endothermic reaction running on hydrogen and maybe methane if some waste oil is added.
   As far as the cooling is concerned, it shouldn't be a problem because of all the mass heat.  Maybe get a chance to test next week.  I'm glad my friend up in Alaska put me up on this site.  Getting some good response at last.  Thanks.  Joshua.
Mar 8, 2010. 11:30 AMlemonie says:
Stuff that someone else has already published is more appropriate in a Forum topic, this area is for things you made.
L
Mar 8, 2010. 2:44 PMrimar2000 says:
Please, have piety of we the non-anglophone: put captions that we can read. In English, of course, I am not pretentious. Youtube has a feature that do it automatically, using your voice.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:road2perfection
