Sonic Screwdriver Mark Vii
5,825
167
17
Posted
Introduction: Sonic Screwdriver Mark Vii
I just finished another Sonic Screwdriver commission with a pretty cool set of features.
This sonic's magic:
It lights up and makes the correct sound for the show
It turns Tvs on and off
A second button controls a laser pointer
The emitter can be extended from the handle
It is rechargable and can charge phones
It still does not work on wood.
As always if I am unclear or you would like to know more, please leave a
comment or message me and I will do what I can to explain/help. For instance, due to a comment I recently uploaded my sketchup design file I used for this prop, which adds to the quality of this instructable. If you know how to use the program, it is easy to pull out dimentions. If not, it is a really easy program to use.
The standard electronics can be found at:
https://www.instructables.com/id/Working-Sonic-Screwdriver-Version-30/
More information on my other projects can be found at: https://www.facebook.com/dancorriganproperties/
Step 1: The Handle
The handle of this sonic screwdriver was saltwater etched to give the cool textured effect, then a slot was milled for the buttons to follow using my Taig lathe.
How it works:
Paint on an electrical insulator (I used nail polish here) where you don't want etched
Make some very saturated salt solution
Connect the negative end of a 5-9 volt power source to a q-tip and the positive end to the part to be etched
Dip the q-tip into the salt solution and drag it slowly across the area to be etched. It will hiss and slowly eat away the metal.
The higher voltage you use the more agressive your etching will be, but it will also produce chlorine gas which smells terrible and damages any soft tissue it touches (lungs, eyes, etc.)
A better set of instructions can be found here:
https://www.instructables.com/id/Salt-Water-Metal-Etching/
Step 2: The Battery
To power this sonic I minimally modified a portable phone charger that fit inside the handle of the sonic. By adding two wires to the USB connection I was able to tap into the 5 volt power source and still use the charger for its intended purpose, charging phones.
To save repitition I put these instructions in their own instructable: https://www.instructables.com/id/Rechargable-Batte...
Step 3: Placing the Battery in the Handle
With the battery done I expoxied it in place using JB-Weld and left those pieces alone overnight.
Step 4: The Handle Top
In my design, the top of the handle has three small brass cylinders that match up with the claws.
I started with a piece of 1" hexagonal aluminum in my lathe, cleaning the bottom face of the part
I then marked the part by cutting a small groove in the face with my cutting tool and used the headstock nut on the lathe to divide the part three times.
The holes were then drilled using an 1/8th inch drill bit
After turning down the bottom of the part to fit inside the handle, I drilled the centre hole big enough for the plastic tube I was using and machined the correct profile into the top of the part.
A bit of epoxy holds the brass rod inserts in place (not shown)
Step 5: The Button Assembly
The buttons for this sonic had to move with the emitter setup, so
I built them into the plastic tube that slides through the top of the handle and connects to the emitter head.
To make the part I started by epoxying a stopper made from metal tubing onto the bottom of some 5/8" rigid aquarium tubing so that the buttons would not slide out of the handle.
I then drilled out two holes for the buttons. The top button turns on the lights, sound and tvbgone and the bottom one turns on the laser pointer.
After a bit of clean-up I fit all of my electronics into this assembly leaving header pins on the top and bottom to connect to the emitter and battery respectively
Step 6: Assembling the Emitter Head
Once the buttons and circuitry were in place I could begin assembling the sonic in its final form.
To start I added a piece of rigid black cloth around and below the buttons to cover the wires connecting the battery to the electronics. When the emitter is retracted the cloth slides past the battery.
The 1/2 inch copper adapter was then added (fits over the plastic tubing like a glove and is epoxied in place)
Once the battery was connected to the circuitry (and the circuit tested) I slid the whole thing together and epoxied the top of the handle in place.
On the copper connecter part of the emitter are three small brass tubes. They each have a hole drilled in the side that lines up with holes drilled in the copper connector. One holds a laser and another holds the IR LED that turns tvs on and off.
Step 7: Adding Claws
One of the flashier parts of this sonic screwdriver are the claws I added to the front end.
To make them I first printed out my design in scale using my cad software.
I then took a piece of copper sheet and sandwiched it between two brass sheets using epoxy and glued three designs to one side of the sandwich.
Once the epoxy was dried I drilled the holes in the claws using a drill press and a 1/16th inch drill bit
I then rough cut the pieces using a band saw and filed/sanded them to their final shape.
With the pieces in hand I used JB-Weld to epoxy them to the emitter. To prevent them from moving while the epoxy dried I used a bit of low temp hot glue to hold them in place.
The next day the hot glue peeled off easily and the sonic was complete.
Thank you for reading my instructable. More of my work can be found at: https://www.facebook.com/dancorriganproperties http://dancorrigantheatre.wix.com/home
If you would like to talk to me about a prop commission, please private message me.
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    17 Comments
    Hi, I am so excited to do this project, but it doesn't tell me what electronics to put in the sonic screwdriver and where to put the electronics. I have been looking for a sonic screwdriver tv-b-gone from scrap. But it seems unfinished because of this. Could you fix this?
    sorry if I am bothering you but how log does the pipe have to be
    Tis not a bother at all.
    The aluminum for the handle is 5.25 inches long.
    If you know how to use the 3d modeling program sketchup, I am going to post the design file with this instructable.
    What is the body made from again?
    The silver colored pieces are all aluminium, then there is some brass and copper. The main handle is a piece of 1" aluminium pipe
    Where should I get a tube? Also what can you use for a handle top and cylinders around the head piece? What is it anyway?
    Also can you list materials on your next one.
    At lowes/home depot/ace hardware they sell 1" aluminum tube, though you might need to get a much longer length than you need. You can get 12" lengths on Amazon as well.
    For the handle top I custom built the piece from some 1" aluminum hex rod that I ordered off amazon a long time ago. It got turned down using my taig lathe (http://www.taigtools.com/) The main handle piece was also modified using the lathe.
    The clear cylender is acrylic tubing from amazon, the silver tube on the clear tube is a former shower rod, the black piece inside the clear tube is a bit of acetal rod ordered on amazon, the copper piece on the very front is a 1/2 female adapter found in the plumbing department of any hardware store, and the small gold colored tubes on the very front of the device are 1/8" brass tube I picked up from the hardware store.
    Hope this helps!
    What size pipe/nipple did you use to fit the battery
