Step 5Battery In
Scratch up the positive and negative terminals of the battery with a hobby knife so that way solder will stick to it. Use a low watt soldering iron (you do not want to apply too much heat to the battery) to solder the correct wires to the positive and negative terminals. Stuff the battery back in the compartment and tuck the wires in so we can reassemble.
http://store.batteryspecialists.com/kr1500aul.html
Does anyone here find it outrageous how close this design is to one that lets you easily change the battery?
The only reason I am looking at this is that I just bought a 4-pack of heads. My dentist says the newer (FlexCare?) brush does a noticably better job. (I trust my dentist - all the latest gadgets to support but one filling in 10 years.)
There is a review here: http://gadgets.boingboing.net/2007/11/08/sonicare-flexcare-re.html
The review says it is 77% more efficient. Has anyone does an analysis (e.g. Kill-a-watt) to see what it costs to run a toothbrush?
I picked up a 4/5A from batteries plus and it was too long to fit into the orig slot. had to modify the plastic and relocate the crystal. its a good thing I've got a talented EE to help me out when i get into trouble, this wasn't something I would have been capable of on my own.
Also, he warned about soldering on the battery terminals and seemed convinced that the battery with pre"welded" posts would be available online. from his info, welding is much hotter, but also much quicker and soldering changes the battery so the outcome is not gauranteed. So, make sure you take a look around to find the right one dimensionally (it'll save you A LOT of time and effort).
