Soot Sprites
Published
Introduction: Soot Sprites
From the movie spirited away, one of the best animated films. Really simple and takes about 20-25 minutes. #breadwinners
Step 1: Supplies
- Markers
- Glue stick or glue
- A Rectangular Block of Styrofoam
- Small Styrofoam Balls (About an inch and a half in diameter is good)
- Black Paint
- Paint brush (You don't need one unless you like your hands getting messy)
- Wire (Make sure it's not too thin or too thick.)
- Paper
- Wire Cutter
- Scissors
- Ruler
Step 2: Paint the Styrofoam
Get your paint ready and go ahead and paint the round styrofoam. You can add as many layers as you would like. I added two layers to make sure it was dark enough.
Step 3: Add the Wire
Put the wire through the styrofoam. Cut the wire as long as you would like with the wire cutter to add the legs and arms.
Step 4: Insert the Legs Into the Other Styrofoam
Put the legs through the foam and make sure it's deep enough. Put it in the sun for it to dry. It will take about twenty minutes for it to dry. Although it just depends on how many layers you put.
Step 5: Make the Paper Stars
This part is the most difficult. Cut a piece of paper that's about a centimeter wide. Tie a knot into it, but make sure it's just loops. The shape should be a pentagon. Gently crease it and take the shorter end and wrap it to the other side. Do the same thing for the longer slide, but this time put it through the loops. Use the scissors if a side is too long. The last step to these stars are to pinch the sides to make the actual star. This can be difficult or take awhile if you've never done this before, so do something to kill time. Like listen to music, watch Netflix, and in my case, chill with your cat. After you're done with the stars, you can use the markers to color them. I used light colors to make them look like sprinkles.
Step 6: Make the Eyes
Cut circles to make the eyes, I made them about the size of my fingernail. After that's done, use a black marker to make the pupils.
Step 7: Glue the Eyes and Add the Stars
Add the eyes by gluing them to the styrofoam. The eyes are spaced apart by about a centimeter. Now add the paper stars on the wire by putting it through the small inserts. You can add as many stars as you'd like.
Step 8: Add Shadows
This step isn't needed, but to make it a bit more realistic I added shading to add a shadow effect. I used a marker below the soot sprite. After you're done doing that, you're done!
    • Backpack Challenge
      Backpack Challenge
    • Stick It! Contest
      Stick It! Contest
    • BBQ Showdown Challenge
    2 Discussions
    I love Susuwatari!!! and these are super cute and realistic O.O!!! Everything "Ghibli related" is lovely in my opininion :) I'm a huge fan of Totoro and Spirited Away (well, actually I'm a fan of all Studio Ghibli films, hehehehe). I recently made an instructable of edible "soot sprites" for a contest, so I would appreciate if you could share your thoughts and maybe vote on my project :)
    https://www.instructables.com/id/Susuwatari-Gremli...
